oil
allen6634
hawesville
600 ford
i took my top cover off yesterday and found that the oil is milky. i thouht no problem i'm rebuilding the lift any way (new oil on the way) , but then i decided to look at the rest of the tractors oil and i found that the transmission oil was milky also. so my question is are or does the transmission and hyd. use the same oil /resivor , or do i have a seal failure, thanks guys i know i have a ton of questions but i'm learning as i go . :D
Ford Tractor from `64 and up to 90?
have one rear end reservoir. Oil spec. are FordM2C 159 A or better, FordM2C 86 A or better. Oil must cover "wet brakes".
Year and modell on your rig ?
/ oil
my tractor is a 1955 640 ford
trans, and then a rear common hyds and diffy sump was the common setup on the 3 cyl jobs..
well.. :( i had a nice detailed post typed up about the 600 series ford and the board vaporised it :( :( :(
in short:
plenty of reasons why you might have water in the trans and hyds.
there is a seal between diffy and hyds .. many leak.
trans , diff, and hyds are seperate sumps.
dump in some atf-f, diesel, and rubbing alcohol 90% in those wet sumps.. drive around the yard.. drain and refill with a UTF oil meeting M2C134 ( walmart, TSC.. etc.. )
2022 CATERPILLAR 299D3 SKID STEER (A62129)
2022 CATERPILLAR...
PALLET OF 11 BARBED WIRE ROLLS (A58214)
PALLET OF 11...
2002 Chevrolet C7500 MTI 805B-47 47ft Bucket Truck (A60352)
2002 Chevrolet...
PNEUMATIC GREASE UNIT (A58214)
PNEUMATIC GREASE...
4021 (A59228)
4021 (A59228)
DRAGON 500 BBL FRAC TANK (A58214)
DRAGON 500 BBL...
