MF 1428V broken frame
   / MF 1428V broken frame #1
Gondela
Maine
L3400, Mf 1428
Thought I was stuck until I noticed the axle wasn't perpendicular to the tractor. Just behind the rear axle is a casting that the front axle drive shaft enters the rear of. This casting bolts onto a frame piece that runs parallel to the axle. This frame piece is broken at both ends where it was welded to the long frame pieces. Rewelding this seems like just delaying the next breakdown by not much. The repair weld can't be as good as the factory welds. Has anyone had this trouble? Got any ideas?
First is the frame piece, the casting belongs where the bolt threads are showing. IMG_20120919_155018.jpgIMG_20120919_155048.jpgsecond is the casting, notice the drive shaft cover is torqued, shaft is broken
I said that because the factory welders had controlled conditions and new materials. Now there are wires, the engine and lots of stuff in the way.
   / MF 1428V broken frame #6
I would re-weld, you should be able to loosen the frame from the engine enough to get a good weld. I would look into getting a welder to look at the damage and maybe he could give an idea of how to reinforce the repair so it will last.
Good luck.
Craig
   / MF 1428V broken frame #7
The new frame cross member that goes between the frame rails is longer which allows for a better weld on both sides of the long frame rails. You cna reweld the one you have and then simply reinforce it by welding a short piece of angle iron around it (kind of like wrapping the corner wit hangle iron).
That sounds like a good plan.
2002 FORD F-350 XL SUPER DUTY FLATBED TRUCK (A60430)
2002 FORD F-350 XL...
Bush Hog 72in Rotary Brush Cutter Tractor Attachment (A55852)
Bush Hog 72in...
1980 Gleaner F2 with heads (A61307)
1980 Gleaner F2...
2014 International WorkStar 7300 4x4 Altec AA55E 55ft. Material Handling Bucket Truck (A60460)
2014 International...
2012 VOLVO A40F OFF ROAD DUMP TRUCK (A60429)
2012 VOLVO A40F...
2014 Nissan Rogue SUV (A59231)
2014 Nissan Rogue...
