Front-End Loader New Kubota Loader on my old L345DT
   / New Kubota Loader on my old L345DT
Kevin, Since I'm only seeing this now, this give-and-take may be setting a record for most drawn-out thread !
If your loader valve has a "power-beyond" port - usually marked PB on the valve, you can connect a hose from it to the back port on the block to supply the 3-pt hitch. (exhaust flow from the loader valve still goes to the trans).
   / New Kubota Loader on my old L345DT #22
Blast from the past on this post! I managed to figure it out to work around the lack of a PB port in my loader valve. It isn't going to win any awards for streamlined design but it worked like a champ all summer so I'll take it! Thanks!
   / New Kubota Loader on my old L345DT #23
Got an email about the hydraulic block - I'm posting the answer here. Under the seat there is a 4-bolt cap that connects two hydraulic block ports together. There is an available adapter that replaces the cap - it has pipe-thread holes for fittings. One hose powers an aux valve and the other is to bring pressurized oil back from the aux valve's power-beyond port to run the 3-point hitch.
Now is where I brag about Ronnie Bowman at Tractorsmart.com - a VERY helpful guy. I happened to have one of these adapters - but a friend is also putting a loader on a L345 so I wondered if the adapter is still available from Kubota. The original is discontinued but Ronnie kept digging until he found its functional equivalent - part No. 70050-00279 price $88.30. It is the key part for tapping into the internal hydraulics for these early '80s tractors - so it's worth it's weight in gold. So is Ronnie. Great job.
IF YOU EVER DECIDE TO RETURN YOUR HYDRAULICS TO "THE WAY IT WAS" MAKE SURE YOU KEEP THAT "LITTLE BLOCK W/ 4 HOLES SO YOU TO CAN PUT IT BACK........A REPLACEMENT IS $200.00............SOUNDS CRAZY BUT I TURNED MY SHOP INSIDE AND OUT TO FIND THE ORIG. TO CAP THE SYSTEM..........
   / New Kubota Loader on my old L345DT #24
How did you move your exhaust to avoid the loader?
2016 Chevrolet Impala Limited Sedan (A55853)
2016 Chevrolet...
IRanch Dump Hopper (A55851)
IRanch Dump Hopper...
2015 Ford Taurus SE Sedan (A55853)
2015 Ford Taurus...
2015 Land Rover Evoque SUV (A53424)
2015 Land Rover...
1995 CATERPILLAR 928F WHEEL LOADER (A52707)
1995 CATERPILLAR...
(APPROX 15) 6" X 2" X 68" TUBING (A57192)
(APPROX 15) 6" X...
