I need to post this to identify what was wrong with my tractor. The mechanic found it right away and fixed it at a very reasonable cost. His bill said: Found drive shaft coupler's snap ring was not installed which allowed the coupler to back off. Reinstalled coupler and snap ring and problem solved.
The 4 wheel drive quit working on my 3510, too. I recently had the hydraulic pump rebuilt, and wondered if the 4x4 could be affected by the hydraulic system(?)
I've thought the 4 wheel drive shift lever has always been a little weird to operate since I bought the tractor [used] a couple years ago. The lever only travels about half way through the lever slot opening, and I can tell there's a slight 'clunk' when it goes into 4x4. When I first got it, I thought the lever needed to be all the way down and when I put some pressure on the lever, I could hear what sounds like gears grinding, like it's trying to go in gear with gears still turning. So I thought the 4x4 wasn't engaged. But later I found the 4x4 worked fine, so the lever isn't all the way forward in the slot when it's engaged.
Anyway, the 4 wheel drive is definitely not working now. Could the shop have done something when they rebuilt the hydraulic pump?
- djb
I thought the 4 wheel drive shift lever was involved with the hydraulic system somehow(?) I need to take a closer look.Not very likely, the 4x4 system is all 100% mechanical - hydraulics should have absolutely no affect on 4x4 operation.
If your 4510 is the same as my 4110 in the trans., the 4x4 shift fork is very easily bent and/or broken. It really isn't fork shaped, it's just a single rod that engages the collar of the 4x4 gear. The gear is splined inside and slides along the 4x4 shaft inside the trans and the outer gear teeth engage it's corresponding gear that is on the rear differential pinion gear/shaft - it has no syncronizers or anything and with the leverage of the 4x4 shifter it bends that single finger inside very easily. Mine used to get bent simply from my left leg resting against the shifter all the time. I heated my shifter with a torch and bent it away towards the fender more and haven't had a problem with my shifter fork since. I'm also very easy on shifting it, rocking the tractor back n' forth between forward & reverse to shift it in or out of 4x4 and being very light on the pressure I use on the shifter. Unfortunately you have to drain the hydraulic oil in order to remove the side cover with the shift fork to check it but it is very simple to check. You can use a screwdriver or similar to try to move the gear once the cover is off to see if it's OK. I've had to do a rear split on mine once to replace the rear bearing on the 4x4 shaft - it had disintegrated and I lost 4x4 because of it. Was one big job to install a bearing that cost me less than $4 at NAPA !! Hopefully yours is just the shift fork. I get mine from Galen at Lawall's and it's less than $20 if I remember correctly. Good luck !!!
