How long will a 10 KW generatoer run on a good new battery??
   / How long will a 10 KW generatoer run on a good new battery?? #31
still need a charge method for the battery to replenish.. maggie will just run the sparkies..
   / How long will a 10 KW generatoer run on a good new battery?? #33
Here is my solution. Get good automatic charger (one that switches to tricle) when the battery is fully charged and then run a cable from the house to the charger. Just make sure that it is on a circuit that is also powered up when the geny is running. That way the charger is powered either from the grid or from the geny. It should be prety simple to do.
I hooked up my CTEK 3300 charger just that way today. Hope that works, and can't see why it wouldn't.
   / How long will a 10 KW generatoer run on a good new battery?? #35
So im going to assume 1 of 2 things
1) the genny is hard mounted at which point i would put wire a grid power reciptical in the generator encloseure and use a HF (or simular) float charger. (i really dont care that the float charger wont work when the grid power is off)
2) the genny is not hard mounted and stored in some garage/shed location at which point i would do the same as 1) just remember to unplug it before you roll the genny out of the garage/shed.
   / How long will a 10 KW generatoer run on a good new battery?? #36
I would wonder if there wasn't something wrong with the generator. I've just never heard of a generator that didn't charge its own battery. If that's the case I'd get adifferent generator.
Good luck.
Yup, piss poor desgn, an electric generator machine that won't charge it's own battery.
   / How long will a 10 KW generatoer run on a good new battery?? #37
something like that. got to have the battery up. when it's running.. it can charge itself if you give it a way to do so. ie.. regualted charger on a recep.
2015 Chevrolet Traverse LS SUV (A56859)
2015 Chevrolet...
49205 (A55788)
49205 (A55788)
(APPROX. 480BF) 1X6X6-16 WHITE PINE TONGUE & GROOV (A52706)
(APPROX. 480BF)...
2019 GALYEAN...
Freighliner Tender Truck (A55315)
Freighliner Tender...
New Holland WorkMaster 37 (A53317)
New Holland...
