10' 2 x 3 lumber?
/ 10' 2 x 3 lumber? #1
offroadaudio
Member
York County PA
Kubota B7800
I'm in the middle of a build, and would really like to save a few inches in the room by using 2 x 3's - but I'd need 10 footers - anyone ever seen 2 x 3 x 10'?
Thanks.
/ 10' 2 x 3 lumber? #2
No, for interior walls 10' 2x3 IMO would twist and warp too much. But if you are doing a basement 2x's on the walls flat will work fine secured to the wall saving space.
Its an inch.. so depending on your specific application you could rip down 2x4x10's for a non load bearing wall or better just rip 2x6x10 in half would be better use of $$ and time.
/ 10' 2 x 3 lumber? #3
Rip fence on the table saw or circular saw is the only way I have seen that size. One would hope this is not structural.
/ 10' 2 x 3 lumber? #4
Thanks.
Are we talking about studs? Are they structural? Are we talking about 2 additional inches in any dimension?
I don't think it's worth the trouble or expense. What would you use for the bottom and top plates?
/ 10' 2 x 3 lumber? #5
I'm sure you could get something like that milled out at a lumber yard but I would think it would result in a bit of a spongy wall.
If that space savings is important another thought would be to frame your wall with the 2x4's on edge.
Actually the only 2x3's I've ever seen were ones I sawed myself.
I'm still thinkin' a 10' 2x3 wall is going to be less than structually satisfying.
/ 10' 2 x 3 lumber? #6
I haven't seen them at a lumber yard. Three things come to mind as to what you could do:
1st You could just buy 10' 2X4's and cut to the size needed.
2nd If there is a lumber mill close to you you should be able to order a custom cut from them.
3rd Have you done the math? By that I mean how much square footage are you going to gain? For txample, if the shed is 10X10 you would gain less than 1. sq ft using a 2X3 instead of a 2x4.
To me, that gain is not worth the extra work or expense to achieve, however, that is only my opinion.
Ken
/ 10' 2 x 3 lumber? #7
2X3 studs are common anywhere commercial work is common. They equal in thickness a 2 1/2" metal stud. In the Seattle area, one can go to Dunn's in Bellevue, and they will even have fire-treated 2X3 wood studs. Go forty miles north to Arlington to ask for 2X3's, and they'll look at you like you just landed in a space ship.
Go ask your lumberyard, they should be able to order them with ease. Alternately, you could consider using 2 1/2" X 24 gauge metal studs for your partition walls. In any case, I would recommend 5/8" GWB used in any construction of thinner walls, for increase rigidity.
/ 10' 2 x 3 lumber? #8
I don't think you could put wiring in the walls. You need 1 1/4 inches clearance on each side of the wire. It might be too tight.
/ 10' 2 x 3 lumber? #9
One word (albeit hyphenated): nail-plates
/ 10' 2 x 3 lumber? #10
Thanks.
I have thought of the same thing before but I was thinking of dividing a 2X4 but I don't believe I would do it. A 2X4 is actually 1 and1/2 by 3 and1/2 so you would only be giving up 1/2 inch on each wall and if it was a dividing wall that would reduce it even further. Is a 1/2 inch really that important? If it is then why not turn the 2by4 sideways and that way you would be increasing the size by 2 inches if I am thinking right. Are you intending to insulate that wall? If so are you going to use sterafoam? I was thinking of doing that in my basement and putting chipboard over it and then if I felt I wanted a more finished look I would go from there.
/ 10' 2 x 3 lumber? #11
Thanks.
That doesn't seem like enough information to understand what you are doing. But if you put two 2 X 4s flat against each other (actual dimensions of each stud is 1 1/2 X 3 1/2) you'd have 3 inches. So you'd have an actual measurement of 3" X 3 1/2 Inches, and good stability.
Dimensional lumber is not really 2 inches. It's 1 1/2 X 3 1/2, or 1 1/2 X 5 1/2, etc.
A 2 X 4 wall offers the minimum strength in the best of conditions and a ten foot wall would be very weak.
/ 10' 2 x 3 lumber? #12
Without knowing what you are doing, I agree with others and just go with 2x4's. I used 2x3'x in my basement, but those were 8' length. I havent seen them longer than that. And the cost difference between 2x3 and 2x4 is minimal.
/ 10' 2 x 3 lumber? #14
2 1/2" metal studs are commonly used in walls up to 12' high. May have to go go 20 gauge studs
KUHN KNIGHT SLINGER 8118 SPREADER (A63276)
KUHN KNIGHT...
2019 KUBOTA KX033-4 EXCAVATOR (A60429)
2019 KUBOTA...
40in. Skeleton Bucket Excavator Attachment (A61567)
40in. Skeleton...
2015 Hustler Raptor Zero Turn (A63116)
2015 Hustler...
429905 (A61165)
429905 (A61165)
UNUSED WOLVERINE SWDB-11-84W HYD DOZER BLADE (A62131)
UNUSED WOLVERINE...
