Always !!! lower your 3PT attachment when leaving the tractor!
/ Always !!! lower your 3PT attachment when leaving the tractor! #21
Reminds me of something my ex-father in law did many years ago.
He bought a 3ph post pounder and was so excited to see what it would do- he pounded his foot! Lucky for him the ground was a little squishy. Not sure if he lowered the whole thing or the striker hit him.......doesn't quite matter, always know where your feet are!
Of course, it would also need to be said- Know where your feet are AND move them if they will get hit........
/ Always !!! lower your 3PT attachment when leaving the tractor! #22
I'm glad that you escaped serious injury. Thanks for posting in regards to Safety issues. Accidents can happen to Anyone at Anytime.
/ Always !!! lower your 3PT attachment when leaving the tractor! #23
steel toed boots are ALL designed to fold! it is cheaper (and easier) to reattach a severed digit that try to repair a crushed one!
/ Always !!! lower your 3PT attachment when leaving the tractor! #24
I don't know if expensive steel toed boots provide more protection than OSHA certified cheap versions. I have two pair and both are cheap with famous brand names not famous boot maker labels. I suspect that when you pay more you get a better fit and longer lasting or waterproof boot but I'd be a bit surprised if the toe protection itself was much different. At least I would like to believe that OSHA standards mean something.
This was about 20 years ago. The boots I had on came from Kmart. I do not know if Osha established a standard at the time or if this standard was revised in later years as they discovered "cheapies" didn't do the trick. I think it has more to do with just putting in a steel guard in a shoe. Leather thickness and the strength of the conformation of said leather has to add more protection than a cheaply made shoe. I've had good just leather boots that if a person stood on your toe, it would not deflect the leather. With no more horses, that is all I wear now. Also, I'm thinking that a good steel toed boot can perhaps exceed the current standard and thus give better protection from that occasional errant horse or roving hippopotamus. I don't know what the pounds per square inch my boot folded under that day but it may have exceeded the then current Osha standard. I was actually glad I had them on as all I suffered was a score line across my metatarsal along with some heavy bruising.
/ Always !!! lower your 3PT attachment when leaving the tractor! #28
Not a tractor but a car, similar situation.
Was working on my '79 Firebird Formula, had the front end up on ramps, gravel driveway.
Somehow the car shifted, the ramp end of one ramp lifted up enough to come down on the tip of by boot, effectively pinning my foot under the edge of the ramp.
I was working alone in a very rural location, didn't expect anyone to come around for hours.
Scared the heck out of me. After my "%^$##@$ unpuckered and my #$^^% descended it occurred to me to untie my boot. Fortunately all of my toes came out of the boot attached to my foot.
Went and fetched a jack and retrieved my boot from under the ramp. The ramp had nearly removed the tip of my boot.
Never used ramps on a gravel surface again after that.
Dave
/ Always !!! lower your 3PT attachment when leaving the tractor! #29
Glad you're ok.
That's an OSHA Focus Four, 'Caught Between'
/ Always !!! lower your 3PT attachment when leaving the tractor! #30
Island, Glad things worked out as well as they did for you. These things happen so quickly and we often forget how easy it is to get into trouble, especially when working alone, as I often do.....Thanks for reminding us all how quickly things happen and how easy and sensible it is to just take the extra seconds and play it safe !!
Glad you o.k.
P
/ Always !!! lower your 3PT attachment when leaving the tractor! #31
Good Mornin Island,
Thankyou for reminding us all of what seemingly wouldnt normally happen ! :eek:
Last summer I was helping the local farmer pickup small squares out in the field. An aquaintance of the farmer was doing the baling chores. This fella gets off the tractor and steps over a revolving PTO shaft, that has no guard on it to boot !!! Ijust lost it, and started hollering at this idiot, I dont think Ive ever seenj something so dumb in all my life, boy talk about tempting fate !!! OK that my rant for the day ! :)
Glad your OK !
/ Always !!! lower your 3PT attachment when leaving the tractor! #32
I think this thread is less about lowering attachments and more about avoiding a tractor with conveniently placed controls. In which case, I know I'll be safe with my tractor ;)
Sent from my SCH-I500 using TractorByNet
Yep. I'm still a big fan of the rear 3pt controller which really helps getting implements on and off but I had ignored the potential downsides and risks. Maybe we should paint the knob orange so it stands out on the gray background. In my case I was looking at the zerk which is about three inches to the midline and about 18" deeper than the knob. I just didn't see that I might bump it while focusing on the zerk. Lesson learned. Might paint it today if I have any orange around.
OK, Domush got me thinking about the risk of accidentally activating and lowering the auxiliary 3pt control lever on the back of Kioti DK tractors. Not sure how many other tractors have this feature. Anyways, I realized that I hit the lever when greasing the zerk for the 3pt control shaft largely because I didn't see it. Of course I know where it is but when focusing on the zerk it is natural to look right past the control lever which is painted the same gray color as the axle and 3pt lift arms. I figured I could paint it orange to make it more noticeable but then realized it would then blend in with the adjacent orange fender. My solution was to zebra stripe the control lever with orange and gray bands so it stands out against either background. I don't know if it is apparent from the photos but the lever definitely stands out more now.
/ Always !!! lower your 3PT attachment when leaving the tractor! #35
Wow. That was a close one. Really glad to hear your ok. Although tough to read I thank you for posting it because it will make all a little more safety conscious. Stay well.
/ Always !!! lower your 3PT attachment when leaving the tractor! #36
Man, I can see how that thing fell, now! That lever is ripe for getting accidentally pushed down.
Thanks for the photo, as I've been trying to figure out a way to add that functionality to mine.
Maybe bending the lever so it faces upwards (or even down) might make it safer?
/ Always !!! lower your 3PT attachment when leaving the tractor! #37
Good idea with the paint. I have visualized what would happen to my foot if I dropped my boxblade on it using that lever... I still love having it back there but its something to be careful with.
/ Always !!! lower your 3PT attachment when leaving the tractor! #38
I must be missing something. I don't mean to disrespect anybody else's experience, but I just don't get it. The lift arms have no downforce, so in order to hook them up, all I do is drop them all the way down, then pick them up by hand and push them onto the implement's pins. I realize that some folks might lack the strength to do this, but I'm hardly a body-builder. Are y'all's lift arms a lot heavier than mine? All category 1 arms should be pretty much the same, no?
I do have to say that I appreciate not having the rear 3pt control lever. It means that if I am going to move the rear implement from the ground, it is much more natural to be standing to the right side of the tractor, as opposed to back near the implement. I'd probably feel differently if I had either a larger tractor, or a cab.
/ Always !!! lower your 3PT attachment when leaving the tractor! #39
As near as I can tell, the rear 3pt control lever on the Kioti/Bobcat tractors is simply an extension that actuates the same linkage as the main 3pt control lever. I have pondered whether, if I really wanted such a thing, I could either weld or bolt something on, instead of buying the factory kit.
/ Always !!! lower your 3PT attachment when leaving the tractor! #40
It's very handy for lining up the top link and for implements that are too heavy to nudge by hand. Also I find that the two lower arms aren't that easy to lift and operate the extension at the same time. You just have to be aware of what's going to happen when you raise or lower the 3pt before you do it.
I imagine at some point Kioti will drop the feature as someone will break their foot and sue, but for now I think its a similar risk level to dumping a load back on yourself with a non self-leveling loader.
2018 Autocar ACX Xpeditor T/A Hercules Front Loader Garbage Truck (A55852)
2018 Autocar ACX...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
Deere 350G LC (A53317)
2012 CATERPILLAR 308D CR EXCAVATOR (A59823)
2012 CATERPILLAR...
2014 Honda Pilot SUV (A59231)
2014 Honda Pilot...
Year: 2017 Make: Ford Model: Fusion Vehicle Type: Passenger Car Mileage: 101,691 Plate: Body Type... (A55853)
Year: 2017 Make...
