3-Point Hitch Compact Kubota 3 pt, hitch
/ Compact Kubota 3 pt, hitch #1
caseihfarmer
blossvale ny
case ihs, john deere, 44 farmall H, Massey Ferguson
Hi everybody, I'm new here so I gotta get the hang of this. I'm a farmer so I'm pretty farmiliar with equipment, but I have a not-so-knowledgeable neighbor. He has a 2011 kubota, which I believe is a B 2360 or something close to that. My question is, is there any way to lock the 3 pt. arms on that tractor so that they won't lift freely when upward pressure is put on them. Any help would be appreciated. Thanks.
/ Compact Kubota 3 pt, hitch #2
Grab a couple wrenches, and take 'em off.
/ Compact Kubota 3 pt, hitch #3
That's normal. Tell us more about what he is doing and why he wants the arms "locked."
Bruce
/ Compact Kubota 3 pt, hitch #4
I don't think so.. I believe they are made to "float" by design.
James K0UA
/ Compact Kubota 3 pt, hitch #5
Run a chain from the drawbar to the top link:
I do this to keep the trailer tongue from lifting if the load shifts aft.
/ Compact Kubota 3 pt, hitch #7
Nice, but what happens if you accidentally hit the lift lever? Won't something bend?
DevilDog
/ Compact Kubota 3 pt, hitch #8
DevilDog
Probably, so don't hit the lift lever. Sometimes playing devils advocate can keep you from getting anything done.
/ Compact Kubota 3 pt, hitch #9
Heh - heh - that's funny and very true.
Actually, on this 12 HP machine the pump just goes into bypass.
/ Compact Kubota 3 pt, hitch #10
<img src="http://www.tractorbynet.com/forums/attachment.php?attachmentid=279858"/>
That is gosh darn clever.
/ Compact Kubota 3 pt, hitch #11
Will youre rate of drop control knob completly block hyd flow? Some units are better than others for that, is kind of a pain to have to do every time you go up and down but depending on the application and pressures involved sometimes locking rate all the way down will work.
/ Compact Kubota 3 pt, hitch #12
Mine will prevent the arms from going down, but as far as I know, won't prevent further upward motion.
/ Compact Kubota 3 pt, hitch #13
Yea, is not the same on all units. I have been around some that will stop travel both directions and some that truly only limit the drop. Was just a thought.
/ Compact Kubota 3 pt, hitch #14
That is correct, none of them prevent the arms from going up. It just prevents the oil from flowing out of the single acting cylinder. Only weight and gravity will evacuate the cylinder thru the drop rate valve, which lets the oil flow back to the tank. Nothing prevents upward movement of the arms. (except that chain)
James K0UA
2015 GMC SIERRA (A60736)
2015 GMC SIERRA...
2014 John Deere 350G Excavator (A60352)
2014 John Deere...
SEMI AUTOMATIC QUICK CHANGE FOR MINI EXCAVATOR (A58214)
SEMI AUTOMATIC...
60'' Skid steer bucket (A61567)
60'' Skid steer...
1999 CHEVROLET C7500 UTILITY TRUCK (A59906)
1999 CHEVROLET...
2022 New Holland C327 Compact Track Loader (A61307)
2022 New Holland...
