dealership nightmare
/ dealership nightmare #1
danwhitworth
kiln ms
kubota L 2350 DT
On Mon aug 13 i delivered my l2350 for clutch and brake repair. Was told they would begin on tractor tues, then wed, then thur then fri u get the pic. Finally the following fri morn called them and said i will pick up tractor fri at 4pm ready or not. When i arrived ar 345 they had 4 of the greasiest mechinics laying in a combo of oil sand and dirt on floor working on my tractor. I observed 1 mech pouring generic oil in trans. When pay bill i am charged with kubota oil (2x price from them) the tractor then would not start, had 3 pt hitch backwards and only 1 bolt in each fender (requires 4). I read label on oil bucket in parts and it dosent meet kubota specs. When i got home i drained oil and saw about 3 dz "love-bugs" and several globs of rust dirt grease etc in 1st 2 gallons. Called another dealer and he is going to tear down check out clean-out and new oil. What can i sue for? The real problem is that the oil wont be noticed for several years of operating then u wont even remember who work on it. Just got a 15 yr old tractor w/ burned out trans, good brakes and good engine Im goin to war!!! DAn
/ dealership nightmare #2
I would call Kubota corporate.
/ dealership nightmare #3
Wow. I hope you took pictures of what you saw. Corporate would want to see them. Good luck.
/ dealership nightmare #4
I would get the second dealer to document what they find. You could have them save the oil they remove and you could have it tested to see if it is Kubota brand or not. You can file a complaint with the BBB and possibly your states atty. You could try to sue but it's probably going to hard unless you can get solid proof. But I would go back to the original dealer and tell them your impressions and what you found. One thing you can do is make lots of noise around town that they are an untrustworthy shop.
/ dealership nightmare #6
On Mon aug 13 i delivered my l2350 for clutch and brake repair. Was told they would begin on tractor tues, then wed, then thur then fri u get the pic. Finally the following fri morn called them and said i will pick up tractor fri at 4pm ready or not. When i arrived ar 345 they had 4 of the greasiest mechinics laying in a combo of oil sand and dirt on floor working on my tractor. I observed 1 mech pouring generic oil in trans. When pay bill i am charged with kubota oil (2x price from them) the tractor then would not start, had 3 pt hitch backwards and only 1 bolt in each fender (requires 4). I read label on oil bucket in parts and it doesn't meet kubota specs. When i got home i drained oil and saw about 3 dz "love-bugs" and several globs of rust dirt grease etc in 1st 2 gallons. Called another dealer and he is going to tear down check out clean-out and new oil. What can i sue for? The real problem is that the oil wont be noticed for several years of operating then u wont even remember who work on it. Just got a 15 yr old tractor w/ burned out trans, good brakes and good engine Im goin to war!!! DAn
Dear Sir: I am somewhat puzzled. In your post, you stated that "I read label on oil bucket in parts and it doesn't meet Kubota specs". You also stated that the tractor wouldn't start, and that the 3 point hitch was on backwards and that each fender had only one bolt in them instead of the required 4 bolts. Did you notice this before you took your tractor Home? Apparently you noticed the wrong oil was used before you took possession of your tractor since you stated that you "read label n oil bucket in PARTS" Did you not check your Tractor out before you picked it up from the dealer? You obviously had adequate time to do so, since you stated that you saw 4 mechanics working on your Tractor and that you even observed one mechanic pouring generic oil in the tranny. I am confused as to why you accepted your Tractor and paid the bill. If you took your Tractor home from the dealer, you obviously had to start it to put the tractor on the trailer. The more I look over and read your post, I am still pondering why you accepted your Tractor without first checking the work performed on it.
/ dealership nightmare #7
Wow, that's a heck of a post :-/
/ dealership nightmare #8
You could try goin' to talk first, original dealer might listen.
Lots of drama for your first post. As Creekbend points out, we could use some more information understanding how this all happened the way you describe.
/ dealership nightmare #9
If I had seen the oil being added as described, the mechanic would have never finished pouring it in. My cell phone camera would have gotten an immediate workout and the manager dragged to the shop by his earlobe.
/ dealership nightmare #10
I might not have gone as far as to drag the manager in by the earlobe, but the oil would have stopped right then and there and I would not have accepted it until the tractor had been flushed to my satisfaction.
Aaron Z
/ dealership nightmare #11
Spot on and what I was also wondering...
/ dealership nightmare #13
So if you watched a mechanic work on your tractor and saw a pail of hydro oil near it that didn't meet spec yet wasn't being poured into your tractor while you watched what would you do? Most people would be cautious but assume a dealership would make sure the correct oil was put in the tractor, sure they might be leery but most wouldn't say a word. Sure he should have looked the tractor over better when picking it up but when you just want your tractor back you don't always spot things. What sort of troll would come here to post yet not bash Kubota and not name the dealer?
/ dealership nightmare #16
Why not. He made some logical observations :confused:
I agree. If you didnt like what was being done to your tractor, why didnt you stop it?
One speculation on the oil, what if they get bulk Kubota oil/hydraulic fluid in 55 gal drums and were re-using a aftermarket bucket to dispense Kubota fluids? Wouldnt be the first time such athing was done.
Aaron Z
/ dealership nightmare #17
I will not even dignify those comments with a answer
Wow is about all I can say. If you want any sympathy or help from us on this board, you certainly aint gonna get it with responses like that.
I gather from the tone of your post that you witnessed something you were unhappy with (pouring wrong oil in). And rather than say anything, you gladly accepted the tractor back, Paid the bill in full, and now want to sue???? I really dont think you will get anywhere.
Its all about proof. You need pictures and you needed to confront them and not pay the bill to get any kind of resolve. Now it is just going to be a he-said she-said. You say the fenders had one bolt. Dealer says they put all 4 in. It isnt hard for someone unhappy to take 3 bolts out of a fender once they get home and then complain to the dealer. Just saying......
And why wouldnt the tractor start the first time???? Obviousy it started now. So you got no complaint at all their IMO. Maybe just something stupid like forgetting to hook a safety switch back up. Or forgetting that they unhooked the battery for whatever reason....
And aczlan makes an excellent point on the oil. And the crud you "claim" came out when you drained a few gallons.....well maybe that was already inside your tractor?? Maybe it needs a good flushing??? Can you prove that it wasnt in their already??. The burden of proof is on YOU my friend. You cannot just make wild accusations. You have to back them up with fact AND PROOF or you are wasting your time.
/ dealership nightmare #18
Well said!! Obviously the tractor started to get out of the shop and on the trailer to get home. The lawsuit will be an uphill battle if you treat the judge just like you did the board members here. Good luck.
/ dealership nightmare #19
Ayep. If the judge feels that you are wasting his time it can do very bad things (like having your lawsuit declared frivolous and ordering you to pay their legal bills).
Aaron Z
(I am not a lawyer, nor do I play one on TV)
2018 TAKEUCHI TL8 SKID STEER (A65053)
2018 TAKEUCHI TL8...
2015 FREIGHTLINER M2 24FT REFRIGERATED CDL REQUIRED BOX TRUCK (A67148)
2015 FREIGHTLINER...
1997 Duraco Dura Patcher 81DJ Towable Asphalt Patcher (A64194)
1997 Duraco Dura...
2016 Ford F-550 Flatbed Truck (A64556)
2016 Ford F-550...
2015 CATERPILLAR 336FL EXCAVATOR (A65053)
2015 CATERPILLAR...
2019 INTERNATIONAL LT625 SLEEPER (A67148)
2019 INTERNATIONAL...
