45 vs 50 hp
/ 45 vs 50 hp #1
joulian
Member
I was looking at the specs and it seems that the 45 and 50 are **** near the same weight. Whats the big deal about going ahead and getting the extra 5hp?
Can anyone tell me what the advantage would be with settling for the 40 or 45 opposed to the 50 which weighs only 40 pounds ( according to my local dealer ) differnt.
I would need a front end loader on it. I have a landscape construction business.
/ 45 vs 50 hp #2
If you are going to be doing some heavy pulling and the cost of the extra HP would be a benefit to you, then the 50 might be the better choice. Eveything else in tractor is the same other than engine HP.
/ 45 vs 50 hp #3
I think for landscape work you would have a very hard time finding any difference between the three. Even mine has more power than traction in low range. If I recall correctly, the 45 is the most fuel efficient by ~5%, somewhere on here is the fuel consumption graphs for all three. But over 2000hrs the 45 wouldn't really pay for itself over the 40. I'd think getting the HST is more important than the HP ratings.
/ 45 vs 50 hp #4
You will have about 10% more power for the occasional job that needs it, like lifting a big rock. When you don't need it, it will cost you a tiny bit more in fuel as the motor is bigger and has bigger friction losses. Trailering will be the same as the weights are nearly the same.
My preference is to get the most power allowed by my other constraints (mainly towing capacity).
/ 45 vs 50 hp #5
I had the DK- 35 and found the lift capacity of the loader was inadequate for my needs, mostly landscaping use. I traded up to the 40 and have not yet found any issue with this model; especially since it has 4 instead of three cylinders. If you are going to be using equipment that could run near max PTO HP then the 40-50 HP issue might come into play, otherwise the 'sweet spot' of the Kioti line is considered the 40 - for most users. Beware the warranty is limited by commercial use- so read the fine print thoroughly. I saw today on the Kioti site they are offering a 5 year warranty on some models now - not sure which.
See my attachment list for type of uses I engage in.
/ 45 vs 50 hp
Towing was my biggest issue when I was looking at the 3 hp models....
/ 45 vs 50 hp
looks like the KL 451 loader is the one to get? I don't know if you have a choice between the KL 401 on the 40-50hp
/ 45 vs 50 hp #8
The DK40-45-50 are the same with the exception of the cylinder size to my knowledge. It is basically the same engine, but bored out to gain the extra hp I think.
/ 45 vs 50 hp #10
If you get a cab, get the 45. If you are going to run PTO attachments that require a lot of hp, then get the 50. Otherwise get the 40.
Just my :2cents:
/ 45 vs 50 hp
I thought the lift (FEL and 3PH) ratings were the same for all three, too.
BOB
If the engine bore is the same it could be just the carb has a bigger jet? I know they do this to mower engines. They will say its a 19hp when all they did was jet UP the 17hp engines' carb.
IS this the situation with the 45 and 50?
THE 451 Loader is discontinued I found out this morning....
/ 45 vs 50 hp #12
No. The spec sheets for all the different models and the engines are on the Kioti site.
/ 45 vs 50 hp #13
i had the option of EX45 or EX50, i went the EX50 option for the extra 5 hp and the fact that it uses larger diameter tyres, for the scrub work i use it for the bigger tyre climb over rocks,logs etc better. have never looked back has done everything i have ever asked of it.
cheers
/ 45 vs 50 hp #14
Orange is not my color tractor but let me ask a question from an innocent bystander.
Does the loader on the 50 Hp tractor have larger diameter pistons or higher psi settings on it's relief valves?
If not and the 40HP can deliver enough psi to trip the relief valves then the loaders will lift exactly they same weight but perhaps not at the same speed.
/ 45 vs 50 hp #15
Yes! Since these tractors are almost identical they probably use the same hyd pump and loader. Thus loader capacity and speed would be identical on each. The weaker engines would just use a larger proportion of their power on the hydraulics. It wouldnt be noticed in many situations.
larry
/ 45 vs 50 hp #16
According to my handy-dandy brouchure, the DK40 has a displacement of 121.98 gross hp 41, DK45 - 134.06 gross hp 45, DK50 - 148.59 gross hp 49. Hydraulic system are all max capacity of 2493, pump capacity all the same, and have the same capacity when using the KL401 FEL. Frankly, I would have gotten the DK40, but the DK45 was less money from a different dealer, so I went that way.
/ 45 vs 50 hp
I found that out today as I called around. The one nearest me was cheaper.
What is an EX?
/ 45 vs 50 hp #18
Lifting a big rock is limited by loader capacity not horsepower. The 40,45 and 50 would all lift the same.
The only real differences i can think of would be in max PTO power, max speed up hill in high range, and max pulling power assuming traction is not a limiting factor. The other consideration for cab models is that the A/C would eat up a few HP on summer days so a 45 with A/C would functionally be like a 40 non cab.
As others have noted, the only differences besides decals and price between the three models is the piston size and bore and stroke. Everything else is identical. Catalog weight differences and other minor measurement differences are either error or simply due to changes in all three over time. For example, early DKse models have a different design and construction of the FEL support bracket from newer versions but those changes affect all 40/45/50 models at the same time.
/ 45 vs 50 hp #20
The only reason I can think of for going the extra hp is to drive implements.
For instance my DK45c falls just a tad shy of the minimum recommended 50hp needed for this particular boom mower I had my eye on.
'course, like boats, you sometimes come down with five-foot-itis. That is, the next bigger size always looks better.
2022 Chevrolet Silverado 6500HD 4x4 Service Truck (A64194)
2022 Chevrolet...
2019 Cadillac Sayers and Scovill 70IN Limo w Only 7729 Miles (A63689)
2019 Cadillac...
CLUBCART CART (A66091)
1997 Volvo WG Day Cab Truck Tractor (A64194)
1997 Volvo WG Day...
2016 New Holland Boomer 47 4WD 45HP Loader Utility Tractor with Bush Hog BH16-2 Brush Cutter (A64553)
2016 New Holland...
2022 EZ-GO ELITE...
