Hydraulic Top Link
/ Hydraulic Top Link #1
Texas Kioti
Member
Hockley, TX
2012 CK30HST
I'm looking at getting one for my CK30H, what kind of setup do dome of you have and are you pleased with it?
I already have the rear remote installed, so the hook-up should be fairly straight forward.
/ Hydraulic Top Link #2
Check with Brian (MtnViewRanch), who sells Fit-Rite Hydraulics. I have one on my DK45 and it just makes everything from hooking up implements to getting them set at the level you want much easier. It is basically screw on the hose connections, purge the system ( which I failed to do correctly the first time), and snap the hoses in place. I think you will like it.
/ Hydraulic Top Link #4
Doug, What did you do for a bracket to hold the cylinder up while changing attachments?
/ Hydraulic Top Link #6
Murphy- My son picked up a clamp that they use on his Big Rig that is rubber covered and the correct diameter to fit on the hydraulic. It has a place I can put a key chain type hook on it and attach it to the existing hook on the DK. haven't seen it yet (he's on the road), but I saw a smaller version of it he showed me when he was in town last week and it looks perfect. For the moment, I'm just using a heavy Bungee cord.
Texas- I believe mine has the Hydraulic Flow Restrictors, but I'm not sure that is what your asking. Brian will let ya know. He's really good about answering questions from folks.
/ Hydraulic Top Link #7
See if you can post a pic of it and maybe where to buy it, the bungee looks redicules
/ Hydraulic Top Link #8
I will as soon as he gets back into town from his trip. I know he got it from one of the truck stops he was at. The good news was it wasn't very expensive.. The bad news was a new Turbo for his Detroit engine as $950 for parts plus $195 labor. That kinda cuts into your paycheck for the week.:( Anyway, he should be cruising in middle part of next week.
Your right about the Bungee and I also smacked myself in the head with the D@mn thing when I released it yesterday.:knockout:
/ Hydraulic Top Link #9
I got one for the Ct235 here. The middle size 18.1-26.4" was a good replacement for the oem.
/ Hydraulic Top Link #10
And do these units have a check valve?
No, none of the links that I build have the DPOCV. (check valve)
Do any of you guys ever try just twisting the OEM hook 90 degrees and then hook onto the hydraulic port?
/ Hydraulic Top Link #12
How do they hold the position you place them in without a CV? What keeps the implement from drifting out of position?
It has been my experience that most of the time if a cylinder used on a Top and Tilt setup drifts enough that it causes a problem, then the control valve or other parts (fittings, hoses) need to be rebuilt or replaced. All that the check valve is really doing is compensating for a worn out or defective control valve & or other parts.
If the DPOCV is such a needed item, then why don't Kubota or John Deere have them on there OEM units? None of the OEM units have them, there must be some reason that they don't. That reason is that it is something that really isn't needed and in fact not even wanted on a side link if the machine has the float function built into the control valve.
There is nothing wrong with having the check valves, and for some instances is probably actually better. But having the check valve can change what options one has when it comes to grading and for some people how they hook up to their 3pt attachments. ;)
Good points, I'll take your word for it. When I told my Dad I was getting a hydraulic top link, he said, "just make sure it it has a CV". Of course he has an old 8N, so maybe he needs one...lol
I placed my order on your website...Thanks for all your help!
/ Hydraulic Top Link #14
Agree CV not mandatory. I just got a hydraulic cylinder, manufactured appropriate interfaces for 3PH/implement attachment and have used it now for 4 years. Drift not a problem. Excellent improvement to 3PH hookup.
/ Hydraulic Top Link #15
I did a mockup with a coat hanger and it was too short to reach either the upper or lower port. I think the thing my son got will do the trick and frankly, I only have it up when changing out implements. I rarely don't have something hanging off the 3 pt.
/ Hydraulic Top Link #16
I tried grabbing the hook and bending it and the whole tractor turned with it. Brian you really need to come up with a universial mount.
/ Hydraulic Top Link #17
Yes, I should come up with something, it would take care of that nagging problem of (now what do I do with this thing) when it's not hooked up to an implement. Maybe I will look at that problem next year at the same time that I measure for the FEL diverter kits that I am going to have in the future. :cool:
/ Hydraulic Top Link #18
Been trying to learn something about these Top Links so thanks for the thread. I have to ask the dumb question, but how do you move the Top Link in and out for the initial hook up to an implement? If you have to climb back and forth from the tractor to move the Link in and out, WOW! Surely I'm missing something. On my little Ford that wouldn't be an issue but on my cousin's M9540 Kubota would be a lot of climbing.
/ Hydraulic Top Link #19
I open the back window on my L4240 and I can reach the levers on my remotes. On a larger tractor where you can not reach the levers on the remotes once you have the lift arms hooked up you could shut the tractor off and push the remote valve forward and backward a few times to take the pressure off then you could move the link by hand.
/ Hydraulic Top Link #20
Most 3pt attachment points are pretty close to the same. So when you change from one implement to another there are a lot of times when no adjustment has to be made at all when hooking up and other times maybe the link just needs to be moved a little one way or another one time. This one reason that some guys like to have the float position on the controls, so that the rod can be manually put where it is needed to be attached.
Sort of the same thing applies to the lower linkage, you sort of have to get it in the right place also. Especially with a bigger tractor, you don't just throw those implements around. After you do it a few times you get use to it. ;)
2006 Generac SD0150 187kVA T/A Towable Diesel Generator (A61572)
2006 Generac...
2020 Toro Groundsmaster 7200 72in. Zero Turn Commercial Mower (A61572)
2020 Toro...
JOHN DEERE 1760 MAXEMERGE XP 12-ROW PLANTER (A64280)
JOHN DEERE 1760...
2006 Hitch and Trailers Inc. 12ft S/A Utility Trailer (A61574)
2006 Hitch and...
LMC Ag 400 Gal Front Mounted Tank (A64119)
LMC Ag 400 Gal...
Volvo EC55B Exvacator (A62679)
Volvo EC55B...
