WHAT DID YOU DO TODAY ?
/ WHAT DID YOU DO TODAY ? #461
Yesterday & the day before I took advantage of my unexpected time off between jobs and did some repairs at one of my rentals.
I knew I had a little bit of dry rot in the brickmold around the windows of the den,and my tenant was willing to assist me with the project for fun. So I went over and started demo on Thursday. I had had a guy make some dry rot repairs maybe 4 years ago when I was traveling weekly and he did a HORRIBLE job, most of what he did was spray foam, molded and sanded and painted!!!!
The dry rot was WAY WORSE that I expected. at one point I was able to just stick my thumb through the plywood and poke it right into the insulation in the wall!!!!! :eek:
Thursday we completely skinned the entire outside face down to the studs and discovered there was NO MOISTURE BARRIER! the trim ha dry rotted, and then it had dry rotted the band board surface and some non-bearing 2x4's under one of the windows!
Thursday we added a large sction of 1/2" OSB from the bottom of the windows to the bottom, added a Tyvek moisture barrier over the whole face, and started on the brick mold. I had made a command decision and I spent the evtra $$$ on pvc trim boards that will NEVER ROT. all the brick mold, 1x4, and trim is PVC, the 1x8's are "Armor Board" supposedly good for 30 years. the decorative molding is PVC, and the 1/4" plywood insets are primered on all edges and the back. This should NEVER dry rot again. Materials cost me about $300.
Friday we finished the complete reskin. Note for scale, the windows are 7' x 2'. th long boards on the sides we had to rip 1/2" off them (we primered all cut edges and bare wood BEFORE assembly, and two coats of KILZ primer on the outside face of the plywood). We also used up the first tube of XST caulk.
My tenant said, it's 5pm on Friday, let's clean up and have a beer. So we did. I need to figure out a good solution for filling the nail holes in the PVC (will wood putty still work?) before I paint.
I'm not sure if I will finish this weekend, or Monday. I also need to repaint the trim around the fromt door, and the bay window trim in the dining room (which thank God is not rotting yet).
Before these tenants move out in the fall (they're building a house out at Lake Anna) he and I will also need to rebuild the two garage door trim sections, because the same shady contractor only flipping spray foamed those repairs also! GRRR!
Be well all,
David
PS - I really feel like I shold be able to sue the original contractor for not having any sort of moisture barrier on exterior wood walls!
I need to finish caulking and paint it.
/ WHAT DID YOU DO TODAY ? #465
TheRumpledOne said:
Hey MossflowerWoods, Nice work!!
Thank ye Sir RumpledOne!
I just rebuilt it the way it had been, with better materials...
:D
David
/ WHAT DID YOU DO TODAY ? #466
I dug out stumps with the backhoe that I have been dodging and mowing around for the last eight years. They finally rotted enough to make them easy. It was never really worth it to spend a bunch of time on each one, but I'm glad they are gone now.
/ WHAT DID YOU DO TODAY ? #467
Today I did the following...
While the wife and older daughters were at the dentist I went to TSC with my baby girl and shopped for a weed burner, then we went home and played candyland (she is 3 1/2).
After Lunch I went back to the big city house and my tenant and I putty'd all the nail holes, and then sanded, and then put a coat of primer on them. I also replaced the broken microwave.
Tonight I'm about to BBQ some "squealer" burgers (chopped bacon mixed into the burger - :licking:) and have a couple beers.
Be well,
David
/ WHAT DID YOU DO TODAY ? #468
David, I've eaten a few bacon cheeseburgers, but never tried chopping bacon up to go in the burger before it's cooked.
And I mowed, edged, and trimmed our yard the one next door this morning, and that's about all I've done; work wise anyway. I did water my wife's potted plants, filled the birdbath a couple of times, filled the birdfeeder, and little things like that.
/ WHAT DID YOU DO TODAY ? #470
Bird,
I use good grass fed beef, so I don't overcook it if I can help it. We chop the bacon and partially cook it in a pan, then mix the bacon (1lb) and 2 lbs of good beef, and 1 egg in a giant kitchenaid mixer bowl, press into burgers and tonight I smoked/bbq'd them over cherry & pear wood, I even smoked the sharp cheddar on top.
We never make bacon burgers the other way anymore.
Scrumptious is the word, and bacon in every bite!
Be well sir,
David
/ WHAT DID YOU DO TODAY ? #471
Bird,
Be well sir,
David
I had some bacon wrapped fresh caught tuna the other night.. YUM YUM!!
/ WHAT DID YOU DO TODAY ? #472
YUM YUM Indeed! :licking: I'll be right over! :D
I was born and raised in Portland Oregon, I happen to know the fishing in Coos Bay is awesome!
Be well sir,
David
/ WHAT DID YOU DO TODAY ? #476
Yesterday I mowed, edged, weed sprayed the 2.1 acre "lake house" rental. I fixed a doorstop also, today I will fix the hole in the wall caused by doorknob due to broken door stop. New tenant walkthru is at 4pm today.
Tomorrow I will be back to caulking, painting etc at the "city house" rental.
Be well all!
David
/ WHAT DID YOU DO TODAY ? #477
Yesterday I also assembled a new mail box & post. Someone stole the last one. Plucked it straight up outta the ground!
I forgot to add this.
David
/ WHAT DID YOU DO TODAY ? #478
David
When we put our mailbox post in, I dug a five ft hole and bolted a loose piece of chain with a piece of rebar attached to the bottom of the post. In 12 years maybe six kids have tried to pull it out and all were in the first few years. They just gave up since all they are going to get from that post is tired..
/ WHAT DID YOU DO TODAY ? #479
PRICELESS!
Yesterday I did minor small repairs to the lake house and had the walkthru with the new tenant, a VERY NICE GUY in the evening.
I patched a hole in the drywall, put 100lbs of salt in the watersoftener, vacuumed, cleaned up the trash burn pile. Little stuff.
Today I need to go back, so one final sanding on the drywall repair and shoot it with primer. The rest of the day will be spent at the big city house finishing the caulking and painting on the bay window.
Be well all!
David
