Mahindra interior cooling problem
/ Mahindra interior cooling problem #1
yanmars
I have a Mahidra 4510. The air conditioning coolant is full, dye was added and there are no leaks. The AC blows cold and the fan works but not strong. With that as a background the cab gets about 20 degrees warmer than the outside air temperature even with the AC on high. This past weekend the interior got to 110 degrees. I have now purchased an auxillary fan in an attempt to get more air circulation. The dealer said if they put in a new factory blower it would be $900, I think that is without labor.
In the past before I got the AC checked and found it was OK I used to remove the doors to make it tolerable inside. Any suggestions.
/ Mahindra interior cooling problem #2
Sounds a little strange to me my 5010 A/C works fine and the fan blows with force. I am going to get the windows tinted just about anything with glass down here gets tinted sooner or later.LOL
As to cost I guess your not under warranty anymore but $900 plus labor that blower better be gold plated?
I hope some one on here will be able to give you some good advise on your problem. Good luck.:thumbsup:
/ Mahindra interior cooling problem #3
I used to do AC service. One of the most common fixes for low performing AC systems was to clean the air filter. Everything nice and clean??. Easy to overlook in the search for a technical solution to problems like yours. Just make sure nothing is jamming up the internal airflow before it hits the coil?. Can you actually reach in and touch the cooling Coil (evaporator) does it have an even cold temp?? Does it have a build up of ice on the coil when it is running?? just a few thoughts. Good luck finding the problem.
I changed all the filters including the interior cabin filters less than 75 hours ago but will recheck everything. Thanks
/ Mahindra interior cooling problem #5
If the evaporator is clogged up with dust and other crud try spraying it with hydrogen peroxide letting it sit for a little while and then spraying it out with the garden hose. I have done this for years on cars and it works great.
/ Mahindra interior cooling problem #6
it the the air flow from the vents is weak i bet the evaporator is dirty.
/ Mahindra interior cooling problem #7
check evaporator core and filter, 75 hrs in dusty environment can plug it up, also blow out and wash out a/c condensor and radiator. Tint will help, does blower work on all speeds?
Dave
Thanks for all the suggestions. When I looked at my manual it showed the evaporator at the top of the cab on the left side. Is that correct or where is it located and how to access it. Thanks
/ Mahindra interior cooling problem #9
Some cabs have a drop down acccess panel, or a flip up roof that is hinged. The evaporator is usualy near the air intake filter. You can follow the hoses.
Dave
/ Mahindra interior cooling problem #10
Did you mean the evaporator or the condenser?? Just trying to clarify?
The evaporator is located on my 4510 inside the cab at the top near the windshield. Looking in with a flashlight it seems clean, I blew air on it and did not detect dirt. To really inspect it looks like that entire section would have to have the screws and bolts removed, some of the control buttons for the fan etc.
I would like to avoid that. Any other thoughts on cleaning/checking the evaporator? Thanks
/ Mahindra interior cooling problem #13
If you spray in hydrogen peroxide let it sit and then hit it with water to wash it out this should help remove anything in it that may be stuck due to the water condensation from being cooler than outside air. Most of the time when doing this the water coming from the evap box drain looks like mud coming out.
2021 CATERPILLAR 301.7CR EXCAVATOR (A62129)
2021 CATERPILLAR...
Bell 1600 Gallon Nurse Trailer (A63118)
Bell 1600 Gallon...
UNUSED KJ 46'X25' METAL GARAGE (A62131)
UNUSED KJ 46'X25'...
2002 Ford F-550 Crew Cab Landscape Dump Truck (A56858)
2002 Ford F-550...
2004 JOHN DEERE 624J WHEEL LOADER (A62129)
2004 JOHN DEERE...
2021 Kubota SVL75-2 Track Loader (A63118)
2021 Kubota...
