BX 54" Fine Cut Deck Gearbox Leaking
/ BX 54" Fine Cut Deck Gearbox Leaking #1
Danner
Gold Member
Kubota BX2660
I've got a pretty good leak in the gearbox on my MMM. The deck is 1.5 years old and has maybe 130 hours on it. Last week, I cleaned and serviced the deck, and topped up the gear oil in the gear box. It took a few ounces, which raised an eyebrow. Then I mowed about 4 acres and the dad-gummed thing was coated in oil, had slung oil over the deck, and got all caked with grass clippings.
I'm not sure where the leak is yet.
Just posting to inquire if anybody else has had this happen and what route they took to fix it.
Thanks
/ BX 54" Fine Cut Deck Gearbox Leaking #2
On my deck(regular 54") there is a seal your are supposed to replace every 2 years I think, maybe yours went bad prematurely. Clean it up with some brake clean and run it a little to see if you can tell where it is coming from.
/ BX 54" Fine Cut Deck Gearbox Leaking #3
Are you sure you didn't overfill the gearbox? When the gearbox gets hot, the oil is going to expand somewhat -- and it needs room to expand or it's going to push past the seals.
Wrooster
/ BX 54" Fine Cut Deck Gearbox Leaking #4
Wrooster
I agree, if this is the first time this has happened the gear box was overfilled and the surplus was either pushed by the seals or was blown out the vent. Suggest checking owners manual for proper way of checking fill level to see if overfilled. Most gearboxes have either a dip stick or a removal plug on the side to check fill levels. I don't know which one your deck has.
/ BX 54" Fine Cut Deck Gearbox Leaking #5
i agree.. may be overfilled.
many gearboxes havew the fill level wel under the input shaft level, and allow the ring gear to pick the lube up and sling it...
Thank you all. I went out at lunch and looked over the deck, which is off the BX at this time. There is oil on the top and sides of the gear box, so I seriously doubt it is leaking from the output shaft seal, which is on the bottom. Also, the input shaft does not appear to be the culprit either. That leaves the drain, fill, and vent. The drain and fill were tight, so, I'm thinking ya'll are correct. I might have overfilled, and pressure is pushing it out the vent. So, I'm going to clean it up tonight and run to see what happens.
Cheers.
/ BX 54" Fine Cut Deck Gearbox Leaking #7
i'd drain it to the fill-to level and then run it.. otherwise it will just get oil again!
Also, to be complete, the fill and drain are both on the side of the case. The full level is to the bottom of the fill hole. The vent is on the top of the gear box. When I filled it last week, I squeezed a bottle of 80W90 oil in the hole, as soon as some started to drain from the fill hole, I quickly screwed the plug in. So, I'm thinking I should have let is sit open a while so any overfill I squirted in could have drain to the level of the bottom of the hole. (If that makes any sense ;-)
/ BX 54" Fine Cut Deck Gearbox Leaking #10
I don't mean to hijack this thread but I have a question. I bought a used BX1500 with a 54 inch deck, how do I know if it is a fine cut or a regular cut deck?
Thanks
ATTENTION PLEASE READ (A60462)
ATTENTION PLEASE...
2010 John Deere 4720 (A60462)
2010 John Deere...
Brock 48'x16' Flat Bottom Grain Storage Tank (A57148)
Brock 48'x16' Flat...
DRILL CABINET SKID (A58214)
DRILL CABINET SKID...
Year: 2014 Make: Chevrolet Model: Silverado Vehicle Type: Pickup Truck Mileage: Plate: Body Type: 4 (A55852)
Year: 2014 Make...
2014 New Holland B95C (A60462)
2014 New Holland...
