some John Deere differences
/ some John Deere differences #1
nohatnocattle
MF202
Hi Folks,
Central WI here, 4.5 acres, many, many obstacles. Just moved in and looking for a late season deal. I will post this same ? over in General Lawn and Garden as well. MOD isn't important, although bagging might be. I have it narrowed down to basically 2(ish) mowers.
1. X700/720/724 series with a 60" 7-iron deck.
2. Z720A with a 60" 7-iron deck.
In general, here are some questions:
  • what is the difference between 7-iron and 7-iron PRO?
  • starting with the x720, they have fuel injection/liquid cooling but I cant tell if the z720 does have EFI? (it looks air cooled)
  • they dont list a bagging attachment for the z720, is that correct?
  • i dont see a residential warrantly listed for the Z720series?
I would probably buy a used X series, 2010-2012, under 100 hours for about $8,500-$10,000 with balance of 4 year warrantly.
A local dealer currently has a new 2012 Z720 for about $7,500.
Any thoughts or opinions appreciated. Obviously, they are two different styled machines. I currently hire a lawn service and the owner/operator has used each style on my lawn and thinks it's a fairly even discussion. I realize the X can be more versatile but I have yet to really pin down another significant use for it.
thanks in advance.
/ some John Deere differences #2
The Pro deck is available on the 900 series Z's. Basically it's beefier for commercial use,and has the Mulch on Demand feature.
Commercial Mowing - ZTrak Mowers
Once you have a tractor,all sorts of things to do with it will come to light.:thumbsup:
I take it,you don't feel the need for 4WD?
I would keep this in mind. A zero turn is a grass cutter.........period! Sure they make things to attach to them,but it's NOT a tractor. Secondly,they are very unstable on hilly/slopey ground.
IMO,it's a no brainer. Go with what is much more versatile. You won't regret it.:)
Greg
indeed they are useful (tractors). I own a MF202.
/ some John Deere differences #4
I had a 2008 kubota pro 326 ZTR (60 inch deck)while I liked it,s speed for mowing all it was is JUST lawn mower.Last year I bought a JD X740(diesel engine) with a 60 inch 7 iron deck.Needless to say I have been more than impressed with this unit as you have many more options than just mowing grass.coobie
/ some John Deere differences #5
Will you be keeping the 202 at the new place? Can it manuever around the obstacles you speak of easily enough to be of real benefit for lawn work? I ask these questions as I have found it helps to have a small 4x4 aws garden tractor for this type of work. Looking forward a few years buying the more feature laden x749 may eliminate the need for a larger tractor after you have the place situated to your liking.
/ some John Deere differences #6
Yep, I've been giving serios thought to trading my EZ-Trak 655 and JD345 in for a X740 with a 7-Iron mower. The Z655 is a great mower, but that's all it is. I still use my 345 about 50% of the time. The only thing I don't like about the 655 and the 345 as well, is they both love gasoline. I purchased 15 gallons of no-ethanol gasoline yesterday to support them.:eek: I should have bought a diesel!
Bill
Wolverine Skid Steer Tree Digger (A64047)
Wolverine Skid...
YANMAR VIO55-6A EXCAVATOR (A63276)
YANMAR VIO55-6A...
JOHN DEERE 5075E TRACTOR (A63291)
JOHN DEERE 5075E...
60� Pine Straw Rake (A64047)
60� Pine Straw...
1998 Ferguson 46B Compactor / Roller (A62613)
1998 Ferguson 46B...
2010 Ford Crown Victoria Sedan (A61574)
2010 Ford Crown...
