UTV for Snow Removal and Yard Work?
/ UTV for Snow Removal and Yard Work? #1
Wiggles92
PA
Kubota
I'm looking to get a UTV that would mainly be used for snow removal and yard work. It would be used for plowing my driveway and the parking lot of my warehouse. It's yard work duties would consist of hauling equipment as well as mulch & dirt. The terrain around my house is very hilly, so it must be able to cope with that.
It must have power steering and a bed/cargo box that can be dumped. Trailer hitch attachment points are a plus. I'd prefer to keep it under $15,000 including the winch & plow, if possible. Also, a decent top speed would be a nice bonus as well since I'd be able to drive it from my house to my warehouse (provided that it's legal to do so), but I have a trailer if that doesn't work out.
I know that there's a Yamaha dealer, an Arctic Cat dealer, and a Kubota dealer nearby, but there may be others as well.
Any and all help is greatly appreciated. Thanks in advance.
/ UTV for Snow Removal and Yard Work? #2
Arctic Cat and Yamaha are unsuitable for yard work since they have permanently locked rear axles which will tear up the yard. Kubota has several models which are very safe on hills because of their hydrostatic transmission, all of which are governed at 25 mph. The smallest of those, the gas powered RTV500 does not offer power steering, so you are probably looking at something in the diesel powered RTV900 series or better. There are several owners of those models that post here regularly. I'm sure some of them will come along soon and respond with more information.
/ UTV for Snow Removal and Yard Work? #3
I run a Kabota RTV1100 and it is great for snow removal. The 1100 ticks all of the boxes that you listed on your wish list. The down side is the price. You will probably be in the 18k to 20k range. A big side benefit of the 1100 is the enclosed heated cab. Sure takes the misery out of plowing snow. Good luck on your rinal decision.
/ UTV for Snow Removal and Yard Work? #4
Sounds like you want an RTV900.
/ UTV for Snow Removal and Yard Work? #5
Kubota RTV 400ci has the power steering, & it's very easy on tight turns.
/ UTV for Snow Removal and Yard Work? #6
Look at the Polaris Rangers. You will be well within your budget. And the Polaris should have turf mode (unlock tne rear diff ) too.
Good luck.
/ UTV for Snow Removal and Yard Work? #7
I have driven two different RTV400cis. It didn't seem like either one had power steering, although the steering wasn't particularly heavy. Since the 400ci is designed at a price point below the RTV500, which has the same chassis and no power steering, power steering would seem rather odd for the lowest end unit.
The 400 doesn't have the hydro advantage on hills, either.
RTV400/500 Specs
Misfire
/ UTV for Snow Removal and Yard Work? #8
Good luck.
Only works on flat ground. No Polaris model allows 4WD drive without a locked rear differential.
Misfire
/ UTV for Snow Removal and Yard Work? #9
RTV400/500 Specs
Misfire
Thanks Misfire for the correction of my steering statement. My bad. I have tried all 3 of them 400, 500, & 900. 400 is the lightest IMO.
/ UTV for Snow Removal and Yard Work? #10
I agree on the 400 being the lightest. I have not driven the 900. I drove a used 500 first, immediately followed by a new 400. I mentioned to the salesman, and a Kubota Rep that happened to be visiting, that I thought the 400 had lighter steering. They both seemed puzzled to hear that. I also made some comments about the vibration. The Rep was not particularly happy to hear what I had to say. Hopefully, yours isn't too bad.
/ UTV for Snow Removal and Yard Work? #11
The 400 does not have power steering. But it really doesn't need it.
/ UTV for Snow Removal and Yard Work? #12
Yeah I was not impressed with all the vibration! My friend bought a 500 because of it. It's very smooth and quiet. Both machines perform well however.
/ UTV for Snow Removal and Yard Work? #13
The RTV 500 doesn't seem to need power steering either....even after I put the 66" V-plow on my RTV 500 the steering was still easy.
/ UTV for Snow Removal and Yard Work? #14
I have a 2012 Polaris 800xp, it does have unlocked one wheel drive, locked two wheel drive and full locked four wheel drive. It is very powerful and sets three people side by side comfortable, I'm 6'1, 250 lbs and have plenty of room, it also has tilt steering and a dump bed. They offer Power Steering and you can get cab, heater or any other accessory you want. They have just released the 2013 models and have beefed up the XP. Of course they have a HD model and a diesel model.
/ UTV for Snow Removal and Yard Work? #15
Misfire
I have had a couple of Polaris rangers and they do have turf mode or one wheel drive. The rzr does not have turf mode. The ranger would be good candidate IMHO .
/ UTV for Snow Removal and Yard Work? #16
Misfire is correct, turf mode does not work in 4wd. I am sorry I got ahead of my self. Turf mode is really good for saving the grass in your yard, not for pushing or pulling.
RIPPER ATTACHMENT FOR MINI EXCAVATOR (A58214)
RIPPER ATTACHMENT...
New/Unused Fuel Heater (A61166)
New/Unused Fuel...
2018 Ford F-150 4x4 Ext. Cab Pickup Truck (A61568)
2018 Ford F-150...
2015 MGS GODWIN CD150M PORTABLE DRI-PRIME (A63276)
2015 MGS GODWIN...
JLG 460SJ TELESCOPIC BOOMLIFT (A62129)
JLG 460SJ...
2005 International 5900i T/A Gardner Denver Kill Truck (A60352)
2005 International...
