New tractor - how many remote hydraulic valves?
/ New tractor - how many remote hydraulic valves? #21
I know after putting a hydraulic top link on the bobcat I had it spoiled me and now I want everything hydraulically controlled.
Yup - hydraulic cylinders are relatively cheap - $100 (or less) to $200 or so in most cases .... it's nice to be able to control something from the seat without getting off and interrupting the workflow ....
/ New tractor - how many remote hydraulic valves? #23
I say 2 remotes and a 3rd function. You could run hoses back from the 3rd function and use it as a remotes if needed.
/ New tractor - how many remote hydraulic valves? #24
Or do the reverse like I did. The 3rd function valve is a real expensive pain. I teed into one of the rear remotes and it doubles for the 3rd on the loader.:)
/ New tractor - how many remote hydraulic valves? #25
Sounds like you want my tractor! I have similar needs and equipment aspirations, and this spring I bought a L5740 with two rear remotes and the 3rd function on the loader. I am using my remotes for top and tilt cylinders, and the third function is ear marked for a grapple that I hope to order soon. I love the tractor and it has exceeded my expectations. I am very happy with my choice in hydraulic options too. I was on the fence about the extra cost but I am so glad I found a way to make it happen. If I did need a third rear remote in the future it could be easily added as the framework is already there to accept it. I don't anticipate having to do that though. I have a lot of options with my setup. The top and tilt has been fantastic with my box blade. It makes grading work a breeze. I went with one float detent valve and one standard return which has been a great pairing.
/ New tractor - how many remote hydraulic valves? #26
Your better off to get the 3rd function when you buy it new because they are a pain to put on. Did you read the instructions? I think it take almost a day to do it.
/ New tractor - how many remote hydraulic valves? #27
Agreed! I got my loader 3rd function new before my tractor was delivered for exactly that reason. It's the third rear remote that I did not get, and that is far less work to add later. :)
/ New tractor - how many remote hydraulic valves? #28
3 remotes, a 3rd function diverter (if you are getting a loader) and a power beyond loop. That way you have 2 remotes for top/tilt, 1 for anything else and down the road, you can add a valveblock with more circuits to the power beyond loop as needed.
Aaron Z
/ New tractor - how many remote hydraulic valves? #29
I have dealer-installed triple remotes on my 2008 Mahindra 5525--cost $700
If you want to DIY, Surplus Center has most of the parts you'll need.
Good luck.
2020 MACK GRANITE (A58214)
2020 MACK GRANITE...
Sakai SW354 (A60462)
207283 (A52708)
207283 (A52708)
2013 Land Rover Range Rover Sport 4X4 SUV (A55853)
2013 Land Rover...
2002 AMERITRAIL 32FT GOOSENECK TRAILER (A58214)
2002 AMERITRAIL...
2019 BOBCAT MT55 WALK BEHIND SKID STEER (A59823)
2019 BOBCAT MT55...
