New tractor - how many remote hydraulic valves?
/ New tractor - how many remote hydraulic valves?
Thanks for the input guys.
I'm going with Kubota. All the guys I work with who have tractors have Kubotas and have never had a bad thing to say about them. I love green tractors but I can't justify the diffrence in price I'm finding for what I need. I'm currently looking at the MX5100 or the L5740. If Kubota brings the 0% financing back next year I can swing the L but if not I will only be able to swing the MX payment. I want to go with the L for the mid PTO but I can deal with backing up if I have to.
Based on what everyone has said... I will go with a minimum of the 3 remotes that Kubota's configurator allows you and going with Bullit's reccomendations. Will a dealer install more than 3 on a new build or do I have to go with aftermarket?
/ New tractor - how many remote hydraulic valves? #12
I just saw a Kubota 0% ad today. :cool2: There use to be a guy on TBN that had 6 rear remotes on his Kubota. I believe that his dealer installed 3 diverters. :cool:
/ New tractor - how many remote hydraulic valves? #13
Seems to me I have read that folks with a log-splitter prefer to have a Power-Beyond set up for high capacity. I dont have a log spliter.....correct me if I'm wrong.
As far as remotes go....I agree that more is better.....but I think with what your planning to operate you can "get along" with two sets. It all comes at a price. I'd like more....but I can operate all my equipment with one set of remotes and a little ingenuity. (of course I'm kinda tight :D) Its seldom that you need to operate all functions at the same time.
There's lotsa ways to spend your money....and they aint all hydraulic. :))
/ New tractor - how many remote hydraulic valves? #14
get 3 remotes on the kubota i have an 7040su fel 4x4 loaded rears cast centers i i only got 2 remotes
/ New tractor - how many remote hydraulic valves? #15
I know after putting a hydraulic top link on the bobcat I had it spoiled me and now I want everything hydraulically controlled. The remotes on these kubota's are expensive.
/ New tractor - how many remote hydraulic valves? #16
If you go with l5740 you can get 2 remotes and a 3rd function for about the same money as 3 remotes. The 3rd function is nasty to install on these tractors.
/ New tractor - how many remote hydraulic valves? #17
normally suggest min of 2 rear remotes. for newbies not knowing what they will get. and suggest 3rd. if thinking about TNT. and if an issue ever arose were an implement needing an extra set of rear remotes. they could just remove the TOP or the TILT cylinder on 3pt hitch and put the old link back on. to free up a rear remote for implement.
if you are going for extras, getting a extra "front remote" to operate grapple, or Fel mount post hole digger or post pounder, or something else. this may give you either a 3rd lever, or a joystick with an extra button on it, or a joystick and lever for front.
high mounted front and rear work lights. is a top option for myself. prefer 2 forward and 2 rear. you may need to get the larger "alternator" option if they give you that choice. on cab models the larger alternator is automatic most times.
you have enough duties, were you will most likely want "split" rear brake pedals, (a separate pedal for right and left rear tires) and have dedicated foot for them. and use other foot for HST pedal / gas pedal / go pedal. kubota on some models place split breaks right above HST pedal. and may make things difficult for you to use them.
get something else than "gear transmission" from HST, to shuttle shift, to other. the tractor will be jack of all trades. and straight gear shift transmission. would most likely be a big pain in rear. in multi projects. that require a lot of shifting and going from forward to reverse.
with all duties you will most likely want AG R1 tires. vs turf or R3 loader tires.
FEL, and backhoe, tend to be high dollar ticket items compared to other implements / attachments. and you will most likely get a larger discount if you buy tractor, FEL, backhoe all at the same time. all other things can be had 3rd party, and just waiting for sales and deals without much fuss.
double check for backhoe. that you can turn seat 180 and operate backhoe. vs getting off tractor and getting on backhoe seat. double check you can remove backhoe, and have access to 3pt hitch.
optional accessories
--to buy with tractor, can be rear remotes. sometimes require special pipe or bends, and can be cheaper up front, vs hauling tractor back and getting them installed at later date. not to mention different valves may be needed on a upgrade later. resulting in more cash out.
--tire type, can be a big one and cab be expensive to switch to another tire type later on.
--larger alternator, to run other various 12v stuff. such as a 12v winch for example. and not draining battery, or extra work lights on tractor.
strongly consider getting rear tires filled with a fluid for rear ballast. before tractor leaves dealers place. it can be DIY. but *shrugs* you may get a discount.
if you are not a welder, see about getting 1 to 3 hooks welded to top edge of front bucket. before tractor leaves dealer place.
/ New tractor - how many remote hydraulic valves? #18
Based on what everyone has said... I will go with a minimum of the 3 remotes that Kubota's configurator allows you and going with Bullit's recommendations. Will a dealer install more than 3 on a new build or do I have to go with aftermarket?
I am getting use to our new L5740; splitting the last eight days between it and our M8540. It is a really nice tractor and I love the swivel seat. I got the three remotes as I got factory TnT. If you are handy MountainViewRanch sells kits which will save you a few bucks over OEM. I didn't get any float valves, live and learn. The MX5100 is also a really nice tractor, but I have to have a cab.
I copied another member and put five hooks on my HD bucket.
Good luck with your tractor.
/ New tractor - how many remote hydraulic valves? #19
My neighbor just bought a L5240. Is is cheaper than the L5740 and has exactly the same engine, etc. It is just rated at a lower RPM.
But to the topic. He had an aftermarket Gearmore T&T installed. It came with 3 valves (two for the T&T and one extra) and of course the hydraulic cylinders and plumbing. It was less than half of the three Kubota remotes.
The negative is that the levers are attached to a rod off of the ROP and looks a little aftermarket.
Edit: Forgot to mention that the Kobata dealer installed it. The dealer thought the Kubota prices were way out of line.
/ New tractor - how many remote hydraulic valves? #20
Part of the issue is how familiar one is with what are the possibilities are ....
For someone without a lot of experience with tractors and implements it may be difficult initially to envision what can be ...
For me it isn't so much operating them at the same time, as much as it is being able to operate without having to futz around with hooking and unhooking connections .... which is usually a somewhat messy job.
True enough .... ;)
2025 MMS MS36C (A60463)
2025 MMS MS36C...
MINI KID DIRT BIKE (A56859)
MINI KID DIRT BIKE...
John Deere Wheel Loader Forks (A60462)
John Deere Wheel...
2014 Bobcat T650 (A60462)
2014 Bobcat T650...
2017 Case CX145D (A60462)
2017 Case CX145D...
2-Row Peanut Inverter (Chain Drive, PTO, 3-Point Hitch) (A61307)
2-Row Peanut...
