Buying Advice JD 3038
/ JD 3038 #1
Blue_Sky
Lower Alabama
2006 2615 4WD Mahindra
I am seriously thinking about buying a John Deere 3038. Hey, what do y'all think of that tractor?
/ JD 3038 #2
There's a few folks here with 3000E series tractors & a fair number of threads regarding their uses. I like mine & consider it appropriate to my needs and a good value at it's price point. It has a strong PTO for it's size and is pretty economical to run - usually in the ballpark of about 1/2 gallon an hour. Mine has about 230 hours on it so far and no problems.
Nick
/ JD 3038
Thanks. I am real close to making the deal.
/ JD 3038 #4
If there is any chance you might be interested in using a hydraulic top & tilt or a grapple in the foreseeable future, get the additional hydraulic remotes added in & included in your financing. It's in the neighborhood of $1700-$1800. I wish I had done so when I set up my purchase & 60 mo. 0% financing ... Also be sure to get the rear tires filled for ballast. They have plenty of power and are relatively light so you need the ballast for traction when running ground engaging tools.
Nick
/ JD 3038
Thanks for the advice. Everything is hilly around here so I will definately get the rear tires filled.
/ JD 3038 #6
I have a 3032e (with only 10 hours), but so far so good. My tires are not loaded (yet), and I can definately see the weight difference (and shorter wheelbase) when brush hogging over bumpy terrain vs the old 1960s Deere 2010 I borrowed.
I think it is a lot of tractor for the money and less to go wrong. Not to say the 3x20 series aren't nice, but I couldn't justify the extra $5500 to go to the 3320 for what I use it for.
/ JD 3038 #7
I own the 3032 and as you have done by reaching out for advise I did the same, after reading and researching I pulled the trigger and I can tell you its everything you need and nothing that you don't great machine it is a simple/basic cut I had a 2320 before the 3032 and tell you hands down that I wish I had bought the 3032 first, I looked at the 3038 at first but did not need the extra pto hp and could not justify the extra 1500 both machines are great
/ JD 3038 #8
I see ypu have a mahindra 2615, how come the change?
/ JD 3038
We also have property in Georgia and I am taking the 2615 there for use on the tree farm. Our other farm, where we live is in Alabama and about 150 miles from the Ga, property. I have been happy with the 2615 - works hard - no problems, but the Deere is a higher hp and I like the features.
/ JD 3038 #10
I don't know if this is true or not, but my local JD dealer told me that the 3038E is John Deere's number 1 selling tractor and that they sell them faster than they can build them.
/ JD 3038 #11
I've got a 3038e with about 75 hours on it and am very pleased. It is a nimble little workhorse and I can go places in the forest I could never go with my old JD 2030 monster. I like the ROPS too. The 3038 is not a powerhouse, but for a small farm or estate it is great. I use it for bush hogging, box blading my driveway. snow removal, general hauling and general clearing - with a Ratchett Rake - of brush and small trees. It works great. I had my ag tires loaded, but they put in too much. I've lowered it to under 70 percent and may go lower yet. More air means less weight but a bit better ride and traction on some surfaces.
/ JD 3038 #12
That's great you'll have the best of both worlds
2016 MULTIQUIP DCA-25SS1U4F PORTABLE GENERATOR (A63276)
2016 MULTIQUIP...
LandHonor LHR-DFP10 Diesel Fuel Transfer Pump (A60352)
LandHonor...
Allmand Maxi-Lite Sho-HD S/A Towable Light Tower (A60352)
Allmand Maxi-Lite...
2018 Ford E-450 Shuttle Bus (A61568)
2018 Ford E-450...
John Deere Decorative Metal Sign (A61569)
John Deere...
2025 BrushFox XHD-78HF 78in Hydraulic Rotary Brush Cutter Skid Steer Attachment (A61567)
2025 BrushFox...
