Front tire loading
/ Front tire loading #1
Code54
Elite Member
Putnam Co. West Virginia
Kubota MX5100, Kubota BX25D,1957 Farmall Cub Lo-Boy Kubota KX91-3, BCS 853
I know there is a LOT of thoughts about loading the front tires but what I was wondering is "why" is it a bad thing. Has anyone ever personally done it and had a problem or personally known anyone to have done it and caused a problem? I guess I don't under stand how adding something like 80lbs to my tires up front can be any worse than adding 120 in suitcase weight directly above the tires? Any thoughts in general?
/ Front tire loading #2
I believe that the thinking is that a person will wear the front end parts out faster having the weight there ALL the time. I have no doubt that the extra weight wears things out faster, takes more fuel to move, etc etc. In the real world of the home owner-user the additional wear and fuel use is so small that for all practical purposes it makes no difference. Do you really care if your tractor wears out 2-3% faster, or uses 1 oz more fuel per hour of use? I have all 4 tires filled on both of my Mahindra tractors, I feel that the additional performance out weighs ANY of the negatives that there MIGHT be.
Just my opinion, others do vary. ;)
/ Front tire loading #3
I have all 4 tire loaded on my Massey. I have heard about not loading the fronts if you have a loader on. With no loader it adds more weight to the front end balancing it for when using heavy 3 point hitch implements. I would not worry about the extra fuel used or tire wear as I think the pluses of the fronts loaded outnumber the bads.
Good points. Seeing the little tractor uses almost no gas I have to agree that would not worry me in the least! I bet I can cut 2 acres of grass on that little B7200 for the same amount of fuel the MX5100 takes to start!
As for the tire wear I have to agree I could careless, heck they will crack up due to age before I wear them out! I am interested in hearing what everyone else thinks. Thanks
/ Front tire loading #5
At 75% fill the rears still have a significant air pocket that helps absorb shock. Fronts filled to 75% have almost no shock resistance. Larger ag tractors do specify loading the fronts which are usually larger than CUT rears in order to dampen wheel hop which is a major concern on large ag MFWD and 4wd tractors. John Deere has a paper with the steps one should take first trying to solve the problem with air pressure changes and then moving on to loading tires in different orders. Ours can get pretty wicked. So front fills are not always verboten but be prepared for reduced tire life, especially in rough conditions.
/ Front tire loading #6
The old Ford 600 in my barn originaly had a mounted trencher, it had iron weights on the front wheels, underbelly frame monuted front blade,loaded rears with iron weights too and the trencher. We still have the front weights but they are no longer mounted. So if you have need for more front end weigth they have been doing it for a long time
/ Front tire loading #7
It does wear parts as well as moving any heavy piece burn more fuel. Tire life on loaded tractors is half of unloaded. Travel speeds in fields is faster with unloaded tires vs loaded tires. Front end wear with a loader is far faster and the farmers that do have the breakage are normally glad when they go to three point hitch ballast to reduce the weight on the front end. Just as I have a recent green trade with a 800 dollar parts bill for the front steering cylinder(every 2,000 hours of ownership he needed to repair it) he was told he could turn with the brakes from the dealer as well as in the owners manual. I asked him not to and he was shocked, after he thought for a minute he said they won't be doing that anymore!
From a dealers stand point of repairs and parts sales, please do it!
/ Front tire loading #8
My dad has a Case 1390 (David Brown 4x4) with a loader and I agree with MHarryE's comment about the lack of air pocket. Being that the 1390 has the loader on, there is no reason for the loaded tires anyway. The tires never seemed to have much of a resistance to impacts with rocks or stumps when loaded. One tire's sidewall gave out and needed replacing, so he did not have it loaded and it is working much better. I had always thought it was because of the lack of air volume.They are AG tires and the fronts are smallish anyways.
/ Front tire loading #9
Like I said, for most of us home owner users, it will make little to no difference. 2000 hours of use will take me well over 15 years to get there. As far as a ruff ride, I guess that I just don't use my tractors like some of you must, because I feel that I get a much BETTER ride with the filled tires. The tractor doesn't feel like it's on balloons.
Each to their own, do whatever you feel is best for YOU. ;)
/ Front tire loading #10
yep.. i have a 10' 3pt mower on a ford 5000.. in addition to a full set of pillow weights up front, I thru on 2 fat plate weights on either side of the bolster to hold that front end down.
on my 4600 i got those iron weights inside the rim dish, plus loaded the fronts.. plus built a big front bumper and grill guard PLUS cast some large convrete weights to hang on her .. it totes a very old and super hd servis (rhino ) mower.
without those weights, when loading on my deckover trailer it does the teeter totter and you look at the sky on the way up.. makes funny 'pinch' shaped divots in the seat when that happens.. :)
soundguy
The tractor I am looking at loading the fronts on is a B7200 4x2 with no loader. The tractor weights approx. 1200 lbs and is used by my wife to pull a cart around the property and to cut grass with a 48" rear finish mower. If I see a good deal on a little tiller I may get that so she can do her garden (its only about 1000 sq feet and flat and she would like to till it herself - hey why argue right) I am guessing we are looking at adding maybe 4 gallons to each tire to get around 75% full. (so lets say about 30-35 lbs maybe) We have a 4x4 MX5100 w/loader so I wont be buying a loader for this tractor and just want to make sure that when she comes up one of our hills she will have the front wheels on the ground and can steer. I have widened the rear tires (turf tires) as far as it goes, adding a factory ROPS/seatbelt, built and added a 50lbs bumper and just want a bit more weight for her. At some point I would like to get rid of the rear mower and get a factory belly mower for her, but until then I need to find some simple ways to add some front weight thus the idea of loading front tires.
UNKNOWN  500BBL FRAC TANK (A58214)
UNKNOWN 500BBL...
JOHN DEERE MX6 ROTARY MOWER, 3PT (A63291)
JOHN DEERE MX6...
KUBOTA SVL97-2 SKID STEER (A64279)
KUBOTA SVL97-2...
2018 F550 Bucket Truck (A63689)
2018 F550 Bucket...
2002 International 9200i Truck (A61307)
2002 International...
Adams 350T 10T Tender (A61307)
Adams 350T 10T...
