yanmar 2002d hydraulic lift
   / yanmar 2002d hydraulic lift #1
winston1
Super Member
gilmer tx
Bobcat CT235
Another project probably not needed but just wanted by me so here tis. My lift slowly leaks down so I decided to order all the o-rings and gaskets to go through it. The way the 2002 lift works it constantly raises it if it drops a minute amount it will pick up a minute amount. Remember all Yanmars are not created equal and this one is quite different than the 1500, 1700, 2000, etc. Took sort of step by step pictures. I have cleaned up and put everything back together except I did not receive the lift piston o-ring. I ordered it this afternoon from Crown products. They indicated it might be in tomorrow. Hoyes did not have it and indicated it could be a week or so to get it. Many of these Yanmar o-rings are Japanese standard and not readily available just anywhere. Enough blah blah blah. Will be glad to answer any questions if I can.
Might just state this one thing. The complete lift assembly as you see removed I would estimate weighs around 100lbs. There is nothing there but steel. Took a couple of pictures looking down in the differential housing and pto assembly. I lightly hones the lift cylinder. The o-ring did have noticeable wear. Hope this cures it.
   / yanmar 2002d hydraulic lift #2
Why are there 2 of these? I guess you could not fugure how to add your pics to this one that you forgot?
Didn't even realize I had done it twice. Sorry about that. If I could I would delete it.
   / yanmar 2002d hydraulic lift #4
maybe it is related to the dbl posting that we get?
   / yanmar 2002d hydraulic lift #5
there is only 8 mins between the 2, this one being the latter?
   / yanmar 2002d hydraulic lift #6
2005 Big Tex 10PI 16ft. T/A Utility Trailer (A49461)
2005 Big Tex 10PI...
UNUSED KJ 20' X 30' METAL GARAGE (A50460)
UNUSED KJ 20' X...
2016 Ford F-450 Knapheide Service Truck with Liftgate (A48081)
2016 Ford F-450...
2005 Ford Escape XLT SUV (A48082)
2005 Ford Escape...
Adams 8 Ton Weigh Hopper (A50397)
Adams 8 Ton Weigh...
2015 INTERNATIONAL 4300 26FT BOX TRUCK (A50505)
2015 INTERNATIONAL...
