3point hydraulic is too sensitive
/ 3point hydraulic is too sensitive #1
manboy
bellingham, wa
yanmar 1510
I have a yanmar 1510 and the 3point hydraulic does not "feather" nicely. If i try to go up slightly, it goes up all the way, and when I try to lever it down slightly, it drops to the ground. Is there some way to control the sensitivity of the hydraulic lever?
/ 3point hydraulic is too sensitive #2
First, yanmars don't have position control like a lot of tractors you might be used to. The valve is a plain hydraulic valve, you must return it to center to stop raising or lowering. Next the lowering speed can be adjusted by closing down on the needle valve located under the seat on the right side. The raising is not adjustable and is quite quick at higher throttle. You could try closing down on the other needle valve under the seat between you legs, but that's not it's designed purpose. It's there to lock an implement up
/ 3point hydraulic is too sensitive #3
Like Byrd said, these (YM186/YM1510) are very difficult to feather. There is about 1/8" of handle motion between nothing and Instant Lift To Top.
A couple of other owners have commented on this and nobody has posted a solution that makes these suitable for grading a road etc.
This surprised me when I bought mine since my older YM240 can be controlled precisely like you would want.
/ 3point hydraulic is too sensitive #4
As California stated, not all Yanmars are created equal. Some models will lift and hold in accordance where you put the handle. Your 186 is not one of those.
/ 3point hydraulic is too sensitive #5
I have a YM2310D and I experienced the same frustration most recently on Saturday. Is there a listing somewhere that shows which Yanmars can do this?
/ 3point hydraulic is too sensitive #6
Not that I am aware of.
Westendorf Loader Bucket (A66408)
Westendorf Loader...
more info coming soon! (A61569)
more info coming...
2023 KUBOTA SVL97-2 SKID STEER (A65053)
2023 KUBOTA...
(32) Kinze Seed Tubes (A65640)
(32) Kinze Seed...
2013 Ford Taurus Sedan (A64557)
2013 Ford Taurus...
2000 LUFKIN FL-II T/A  48FT FLATBED TRAILER (A59914)
2000 LUFKIN FL-II...
