O ring removal and install
/ O ring removal and install #1
kioti pup
Member
Dillon, MT
2011 Dk45se HST
Hi I have a hydro leak and was hoping to change out the o ring but I have no idea how to do this without tearing it to shreds. Any help would be appreciated. The leak is in the female coupler I believe.Thanks! :confused: O Ring.JPG
/ O ring removal and install #2
The seals in my hydraulic couplers look like o-rings, but when I disassemble one they are actually a much more exotic shape.
Cloverleaf rings maybe (think of an o-ring with the cross section of a 4 leaf clover).
Anyway, I would disassemble one and carefully look at the old seal.
/ O ring removal and install #3
if you have a seal company near by go there with the coupler, like CC said it may not be just a O-ring. As far as getting the old one out use a pick shaped like a nut pick but made of a softer material like brass so you do not gouge the seat. You push the pick in on one side then hook the ring and pull it out.
/ O ring removal and install #4
Hi I have a hydro leak and was hoping to change out the o ring but I have no idea how to do this without tearing it to shreds. Any help would be appreciated. The leak is in the female coupler I believe.Thanks! :confused:View attachment 275607
It is simple, use a hooked pick to pull the old one out. Try to leave the backer [usually teflon, white] in there. Push the new o-ring past the groove and pull part of it into the groove with the backer towards the outside of the coupler. Then work it around to complete the install. You should end up with the o-ring then the backer in the coupler from inside to out, the o ring sould be closest to the poppet. CJ
2025 LandHonor LHR-DFP10 Diesel Fuel Transfer Pump (A64194)
2025 LandHonor...
2017 Cadillac Federal 70IN Limo w 27466 Miles, Premium Federal Coachwork, Luxury Transport (A63689)
2017 Cadillac...
2022 EZ-GO ELITE...
Kohler Gasoline Air Compressor (A64553)
Kohler Gasoline...
2015 Kenworth T880 QMC 8060R 40 Ton Tri Axle Straight Boom Crane Truck (A64194)
2015 Kenworth T880...
2017 DITCH WITCH JT20 DIRECTIONAL BORING MACHINE (A63276)
2017 DITCH WITCH...
