hours per year
/ hours per year #1
Johndeere3720
Padawan Tractor Learner, Advertiser
NW Oregon
Bobcat T650, MT55, E42R, E10, John Deere 4410, 4200, x500
How many hours do you put on your tractor in a year? I have noticed a huge jump with my Deere skid steer. My old Yanmar would get about 50-60 hours logged on it every year which would be mostly mowing and scraping dirt. Now that I have my Deere skid steer I am about 6 months into owning it and have already logged 100 hours on it. :D I expect that by the end of the year I will have between 200-250 hours logged on it. So the question arose in my mind, how many hours do you log on your tractor every year?
/ hours per year #2
My kubota is 6 years old and has 365 hours. So thats about 61 hours per year.
/ hours per year #3
332, But cou.d of been 40+ hours more if last winter was not so light.
I will update in the fall when it is 3 years old.
/ hours per year #4
My 07 Massey only has 160hrs. The better the weather the more hours it see's, that's for sure. Been hot hot hot here.
/ hours per year #5
Our '84 JD 950 has 660 hours. We've owned it since '86, and it is primarily used for mowing a 3 acre "pasture" about five times a year. Plowing a little snow and moving firewood is it's other uses.
/ hours per year #6
My 231s Massey had 670 hours on it and was 10 years old when I sold it. Mostly from mowing pasture and a little bit moving snow, and digging post holes.
/ hours per year #7
First Kubota lots of hours in 14 years,Kubota now less than 200 hours since most projects etc. are done.
/ hours per year #8
I have put about 250 hours on in a little over 3 years. I mostly use for mowing and snow removal, and an occasional hay ride.
/ hours per year #9
My 2000 NH TN70D has about 1675 hrs on it for about 140 hrs/year. My old LX565 Skid Steer I owned for 5 years got about 400 hrs/year. Just got a 2007 L190 with 1079 hrs on it last month, we shall see.
Tim
/ hours per year #10
My 1986 Massey has 4560 hours on it. I put on about 250 a year depending on the chores that have to be done. My Case has no hour meter but I guess it gets 10 or 15 hours a year from running at shows and in parades.
/ hours per year #11
My 01 B21 bought new has 440 hours now - early years put on more hours like 50/year now with just maintenance around the place 40 hours a year. Of course the B21 registers hours based on RPM, so it may be more like 550-600 usage hours as I normally run at 1500-1800 RPM doing BH or loader work.
1989 Cub Cadet has 740 hours, and the Ferris bought in 2010 70 hours so can only run one at a time so I log about 100 hours a year between machines mostly on weekends unless we have snow then the B21 gets some excercise.
/ hours per year #12
I bought my Kioti DK35 HST in late March 2011. I have 338 hrs on it so that works out to 253 hrs per year. On my previous lighter, gear tractor I averaged 70 hrs per year.
Although physically larger, the new tractor turns much sharper and the HST is much easier to use for my conditions. For example, I used to use the finish mower just on the pasture but am now able to use it to cut the lawn and retired my old riding mower.
Because it is easier to operate and less physically demanding, I am able to use it a lot more to help my neighbours.
/ hours per year #13
Our Siromer 204S has averaged about 450 hours per year since new in 2008 - although a lot of this was loader & grader work in the first two years, and it has worked less in the last twelve months as our excavators are now used a lot more for field work as well.
The Fiat NH 50/86 has averaged less at about 350 hours - mainly ploughing.
The Case excavator stands at 600 hours for us last year (total hours is nearly 3000)
Our new(ish) CAT excavator has already done 150 hours for us since easrly May...
The Ebro hour counter doesn't work - but to be fair it doesn't get used much as it's too large to transport on our lorry and isn't road legal.
/ hours per year #14
Just traded a B7500 with around 1100 hours - 10 years. Also put hours on a Ford. Depends on grass, snow and projects.
/ hours per year #15
The 2005 John Deere 3520 had 1011hr,I traded for a JD 4520 In march of this year and have 77hr.
/ hours per year #16
In 10 years I've got 2220 hours on the clock. Lots of loader & boxblade work as well as grass cutting, but have done all kinds of things with it at times.
/ hours per year #17
It varies vastly on different machines but 2-600hrs a year each generally
/ hours per year #18
Seems like I am using the new Kioti more and more, 72 hours since mid april 2012. So at this rate over 200 per year, but the last tractor, less than 60 per year, and the tractor before that, only about 20 per year. When I lived in Willard and mowed a lot, I an thinking was about 200 to 300 per year.
James K0UA
/ hours per year #19
I bought my L3700 at the end of July 2010 and by the end of 2011 I had 38 hours on it, almost exclusively mowing. It has been wetter and cooler this year and I have 57 hours on it as of last night. I think the first year I mowed 4 times (had hired mowing prior to buying), the second summer maybe 6 or 7 times (only me mowing). I have already had to mow 6 times this year and we haven't hit mid summer yet. So you can see, my hours vary considerably.
/ hours per year #20
I'm putting about 50 or so on per year. I replaced the hour meter shortly after buying it 5 years ago and it has about 260 hours since. :D
I suspect that if I lived where the tractor is, I'd have more on it because I'd be doing more projects. As it is, I only am there on weekends and run it two days in any given week at most.
Much of that is mowing along with a few hours of plowing snow. Biggest use beyond mowing is playing motorized wheelbarrow and grading. I'm gradually turning some relatively rough terrain into something resembling lawn. Close enough to use the MMM rather than the rotary anyway.
2011 CATERPILLAR 950H WHEEL LOADER (A64279)
2011 CATERPILLAR...
2020 Ford F-250 4x4 Crew Cab Pickup Truck (A61573)
2020 Ford F-250...
2015 Freightliner M2 106 Terex Hi-Ranger TL55 55ft. Insulated Material Handling Bucket Truck (A60460)
2015 Freightliner...
1000 GALLON FUEL TANK (A64276)
1000 GALLON FUEL...
Unverferth Seed Runner 3755 (A64119)
Unverferth Seed...
2006 JLG 2030ES 20ft Scissor Lift (A61572)
2006 JLG 2030ES...
