450 or 440 inner air filter
   / 450 or 440 inner air filter #1
CJONE
Northern Michigan
KIOTI DK50 HST
Rumor has it the the Bobcat tractors have a inner and outer air filter. If someone could get me the inner PN# for the filter I would appreciate it. My tractor looks like it has a place for it and I would like 1 in it. CJ
   / 450 or 440 inner air filter #2
The same Air Filters are used on the Bobcat CT225/230/235/335/440/445/450 tractors.
Inner 6666334
Outer 6666333
Here is a link to a Bobcat Filter Reference Guide:
Inner 6666334
Outer 6666333
I am assuming that is the Bobcat P/N Do you have a Donaldson P/N? Should be on the end of the filter. CJ
   / 450 or 440 inner air filter #4
This surprised me, the Bobcat air filters are not purchased from Daedong but are "Made in Mexico". The only part number is the Bobcat stamped number as indicated earlier.
I would like someone else to verify this but here are the equivalent Bobcat and Kioti part numbers. I think I may have seen this on some forum topic about a year ago???
Inner air filter: 6666334 and E6300-11091
Outer air filter: 6666333 and E7230-11081
Engine oil filter: 6696286 and E6201-32443
Fuel Filter: 6695912 and 84612-4316-0
These are the same part numbers for all Bobcat CT tractors CT225-450.
I have tried to cross both ### and nothing. I'll just go to a Bobcat dealer and buy a inner element. My air filter has a Donaldson pn# printed on the end and i was hoping that Bobcat was the same. Thanks for trying!!! CJ
   / 450 or 440 inner air filter #6
Any decent size lawn and garden dealer will have the filter also. It is the same filter that is ran in most of the commercial zero turn mowers.
   / 450 or 440 inner air filter #7
I am not familiar with Donaldson filters but here are the PN for them:
Found the numbers on the Donaldson website!
Inner air filter: P822769
Outer air filter: P822768
Engine oil filter: P550934
Fuel filter: P502161
Why are you not getting filters from your Kioti dealer?
In my case like I stated before Kioti does not use a inner element, so no PN# listed. Otherwise I get everything else from Michigan Iron. CJ
The inner filter fit perfect, thanks guys. CJ
2023 John Deere 6R 195 MFWD Tractor (A53485)
2023 John Deere 6R...
2009 Ford E-450 Ambulance (A55852)
2009 Ford E-450...
2012 International WorkStar 7500 Vactor 2100 Plus Combination Sewer Jetter Vacuum Truck (A55973)
2012 International...
Generac Yanmar 5000Watt Heavy Duty Diesel Generator (A51691)
Generac Yanmar...
2003 Big Tex 10PI...
TEST YOUR BID BUTTON! (A57192)
TEST YOUR BID...
