450 or 440 inner air filter
   / 450 or 440 inner air filter #1
CJONE
Northern Michigan
KIOTI DK50 HST
Rumor has it the the Bobcat tractors have a inner and outer air filter. If someone could get me the inner PN# for the filter I would appreciate it. My tractor looks like it has a place for it and I would like 1 in it. CJ
   / 450 or 440 inner air filter #2
The same Air Filters are used on the Bobcat CT225/230/235/335/440/445/450 tractors.
Inner 6666334
Outer 6666333
Here is a link to a Bobcat Filter Reference Guide:
Inner 6666334
Outer 6666333
I am assuming that is the Bobcat P/N Do you have a Donaldson P/N? Should be on the end of the filter. CJ
   / 450 or 440 inner air filter #4
This surprised me, the Bobcat air filters are not purchased from Daedong but are "Made in Mexico". The only part number is the Bobcat stamped number as indicated earlier.
I would like someone else to verify this but here are the equivalent Bobcat and Kioti part numbers. I think I may have seen this on some forum topic about a year ago???
Inner air filter: 6666334 and E6300-11091
Outer air filter: 6666333 and E7230-11081
Engine oil filter: 6696286 and E6201-32443
Fuel Filter: 6695912 and 84612-4316-0
These are the same part numbers for all Bobcat CT tractors CT225-450.
I have tried to cross both ### and nothing. I'll just go to a Bobcat dealer and buy a inner element. My air filter has a Donaldson pn# printed on the end and i was hoping that Bobcat was the same. Thanks for trying!!! CJ
   / 450 or 440 inner air filter #6
Any decent size lawn and garden dealer will have the filter also. It is the same filter that is ran in most of the commercial zero turn mowers.
   / 450 or 440 inner air filter #7
I am not familiar with Donaldson filters but here are the PN for them:
Found the numbers on the Donaldson website!
Inner air filter: P822769
Outer air filter: P822768
Engine oil filter: P550934
Fuel filter: P502161
Why are you not getting filters from your Kioti dealer?
In my case like I stated before Kioti does not use a inner element, so no PN# listed. Otherwise I get everything else from Michigan Iron. CJ
The inner filter fit perfect, thanks guys. CJ
12' CONTAINER (A52706)
2016 Ford F-450 Pickup Truck (A51692)
2016 Ford F-450...
2013 FREIGHTLINER CASCADIA (A55745)
2013 FREIGHTLINER...
2007 Chevrolet Silverado 1500 (A55973)
2007 Chevrolet...
2015 Ford F-350 Dump Truck (A51692)
2015 Ford F-350...
Electric Mobility Scooter (A51694)
Electric Mobility...
