Potatoe Advice please
/ Potatoe Advice please #1
wawajake
Canada
Kubota BX2660 , Kubota RTV X1100C
I live in Northern Ontario Canada and we are dealing with a very dry summer.
I have a small garden 30 x 30 that includes three rows of potatoes in the centre.
Now I put the potatoes in the center of garden because they would be last out of ground in fall, and so I could drive my compact tractor across the other crops (by then harvested) to get at the potatoes and dig them up with my tractor bucket teeth . (hard clay type soil so normally use tractor)
But now due to hot summer and bugs etc, the potato plants are just about dead looking, almost all yellow and most leaves shriveld . Now my question is how long in the ground can I leave the potatoes before I harvest ? I was hoping to wait until after my corn crop is done, so I can do with tractor. But if I must hand dig all the potatoes before they rot, then I will.
thoughts ???
Wasn't it your President Andrew Jackson who stated "It's a dam poor mind that can only think of one way to spell a word."
back on topic please ................potatoes
/ Potatoe Advice please #4
My potatos are growing good even with this dry weather. They do get watered every day and they are in sand/loam soil. The potato bugs are my issue. You are probably okay to leave them in there for a few weeks as long as you do not have any mice/moles or bugs that will eat them and the ground is dry.
/ Potatoe Advice please #5
Dig a few plants up to see what you got, then make a decision.
You can also use t he tractor lengthwise on the row. Just have to pick the spuds right away.:thumbsup:
/ Potatoe Advice please #6
Once the tops have dried, that's your indication that the potatoes are as grown as they are going to be. I leave mine in the ground, pulling them 3-5 lbs at a time as I want to eat them, until I start to see signs of bug damage or rotting. The ground is actually one of the best places to store them, IMO, as it is relatively temperature and humidity-controlled. If they are near the surface and sunlight hits any part of them, that part will turn green and start to sprout, which makes it inedible. You can avoid this by mulching them heavily with straw. After I start to see signs of bug damage or rotting (due to excess rain, usually), I pull the rest of them and store them inside.
If you are going to use bucket teeth to pull the potatoes, then coming at the row sideways is probably the best choice. If you have a potato plow, you can drive the row lengthwise.
/ Potatoe Advice please #7
I am seeing the exact same thing right now too.... potatoes dying off early. I NEVER in my life had potatoes die off this early and always harvested it in sept/oct. Looks like I will start harvesting it in july/august now and expect to pay a premium this winter for potatoes for first time in 10 years.:mad:
/ Potatoe Advice please #8
I was told many years ago, that when the potatoes mature, and the vines die, they will keep better in the ground if you cut the vines off. Can't scientifically prove it, but it doesn't seem to hurt.
/ Potatoe Advice please #9
I agree 100% Don't panic.
/ Potatoe Advice please #10
I've been hit with bugs in August- just about killing the potatoes. I left them there until 2nd week of October. Potatoes were not big- but they kept pretty well. Picking bugs is not good enough. You need an insecticide, check out Gardens Alive for Bulls eye for more organic type. Sevin also works.
/ Potatoe Advice please #11
Until the ground freezes. If the ground is super dry it might not be good for them so you might want to water them a bit even after they are dead to keep the ground moist.
/ Potatoe Advice please #12
Once mine start dieing back for whatever reason they are done thats the way it is big or small they did what they could.
I let most all of them get to that point takes a week to two and I mow over them to mulch the tops and then plow them up with a middle buster and get it over with and as soon as we pick them all up I till the spot.
/ Potatoe Advice please #13
The drought will likely cut our production in half this year. Barely keeping them alive through irrigating. It's gotten old. Tough year. Century temps and no rain. What are you gonna do?
I've plowed and dragged the fields in late October and early November and raked up lots of 'taters. Frankly, they were just as good as the ones we picked up in August. No problem. The ones you miss will "volunteer" next year too.
/ Potatoe Advice please #14
Mine died off about 3 weeks ago, all that is left of the plant is a little brown stem. I just left them in the ground and go out to dig a couple hills anytime I want fresh potatoes. It has started to rain quit bit this past week so will harvest the rest this weekend.
/ Potatoe Advice please #15
That was what finally convinced me to leave them in the ground. I would find them weeks later, in fine shape. As long as it doesn't get too wet, or the bugs/mice don't start getting too aggressive, that's far better than trying to store them indoors. Once I pull them, I can only keep them for a few weeks until they go soft and sprout.
Thanks everyone , looks like I will leave them in the ground for a few weeks as long as it does not become really wet . I do have a middle buster and could perhaps take down the deer/dog fence at one end and try to plow them up from middle of garden in a few weeks.
/ Potatoe Advice please #17
my tator vines or deed been that way about 2 weeks but they were planted on april 6 good friday had good growth if you want tour tators to last longer once you dig them if possible they need to be in a cool dry place annd most important cover them so there not in the light we use lots of news paper to cover them like most evryone else im about 2 months ahead this year i normanly don't dig tators till first of september so we will all learn together this time first time ever planted that early.
/ Potatoe Advice please #18
Not potato related but drought and season related I have black walnuts already. In 24 years I have never once seen walnuts on the trees before September going to be a strange winter.
/ Potatoe Advice please #19
Old post but the only one I can find relating to harvesting potatoes with the bucket teeth. Seems like it should work. Does anyone have any tips on what to do or not do?
Thanks, Craig
/ Potatoe Advice please #20
Thanks, Craig
Just dig below the potatoes, dump them out and rake. That's how I harvested mine last fall, as I was recovering from surgery and wasn't supposed to do any lifting. I've also used my backhoe, which worked better but would be a pain to put on and take longer than just digging them.
2019 HYUNDAI V12530152-AJS 53' 102" T/A VAN TRAILER (A59912)
2019 HYUNDAI...
2015 International WorkStar 7500 T/A Dump Truck (A61573)
2015 International...
LIGHT PLANT GENERAC MAGNUM (NON TITLED) (A63569)
LIGHT PLANT...
2019 Kuhn GMD3151TL Disk Mower (A63116)
2019 Kuhn...
SHOP FANS AND MIRRORS (A63569)
SHOP FANS AND...
2017 Freightliner M2 106 AWD Terex Hi-Ranger 5TC55 55ft. Insulated Material Handling Bucket Truck (A60460)
2017 Freightliner...
