Jinma 284 - Cluster Panel Question
/ Jinma 284 - Cluster Panel Question #1
zfreak28
Clay City, Indiana
2005 Jinma 284 LE
Hello,
Just wonder if someone could point me in the right direction.
I just bought a 2005 Jinma 284 with the intregrated cluster panel. I can only get the tail / marker lights to come on.
I started "jiggling" the connector from the fuse box to the cluster panel and I was able to get all the lights to come on for a second, but I have not been able to get it to do it again.
The tail / marker lights always work.
Thanks for any help.
Check the Big white wire in the plug in , it seems to come loose. You may have to put a male /female on them and wire around the plug in
Tommy
Affordable Tractor Sales
"Your Jinma Parts Superstore"
Home of compact Jinma, Foton, and Koyker Tractors and Parts, Wood Chippers, Backhoes - Affordable Tractor Sales Company
Thanks Tommy,
I will check that out this weekend.
Not sure if I need to start another thread, but I have read a ton of the Clutch Adjustment Articles and my clutch seems to be experiencing some of the same symptoms. IE: PTO will not engage unless motor is stopped. The shuttle shift seems to have to wind down if you will before I can shift into the other direction.
My clutch adjustment question is, I doubt very seriously that the clutch pedal adjustment has been touched since factory settings, so do I adjust the pedal so that the pedal is brought up more to the operator, or does it need to go more toward the ground?
I don't want to go "monkeying" around in something if I don't have to... :)
2004 Case JX75 (A64126)
2004 Case JX75...
Corral Walk Through Gate (A66408)
Corral Walk...
(2) 30 Yard Roll Off Dumpsters (A65579)
(2) 30 Yard Roll...
7102 (A61567)
7102 (A61567)
2022 EZ-GO ELITE...
(2) 4 WAY WRENCHES (A64276)
(2) 4 WAY WRENCHES...
