Ordering 3520 have a question
/ Ordering 3520 have a question #41
Order placed 2 days ago.
John Deere gave the dealer a date of Aug 20th delivery ahhh sooo long. ha-ha
I know some people will not agree with what i decided but the payments and numbers worked better for me.
I ordered a 3320 cab not a 3520. I got to demo one and it was perfect for me. had more than enough power and the price came in where i was more comfortable.
2012 John Deere 3320 Cab
300CX loader 73" bucket
72" 7Iron MMM
Will add rear remotes later when i have the need for them. No more freezing my butt off in the winter t-shirt and hot coco snow removal coming my way :)
BlackRaptor,
I ordered the same tractor (3320 cabbed) on June 18th and it was being shown for delivery July 31st. Tractor came in last Thursday (July 5). The invoice showed it was built the day after it was ordered, so it was built June 19th. I think you might have it within 2-3 weeks.
You just made my day :)
/ Ordering 3520 have a question #43
/ Ordering 3520 have a question #44
Good decision on the smaller bucket. Not sure why the larger one comes standard? Congrats on a nice new tractor though!
Brian, if you are interested in JD's 4 in 1's, they sell all the same Frontier (green) loader implements with the JDQA under the WorksitePro (black) name with SSQA. Might be worth a look.
/ Ordering 3520 have a question #45
Unless I missed something in the thread, I think you mis-read... he ordered the 73" bucket.
The reason that the larger buckets come "standard" is because most folks want their loaders for moving material. And, more material at a time is better (most times). Another very common use for a loader is moving snow or other similar material that the tractor might not easily drive through. In those cases, you want a wider bucket to move enough material so that the rears will have a clear path.
For those folks that are looking to dig below grade or move very dense materials, a smaller bucket makes sense.
/ Ordering 3520 have a question #46
Martian, thanks for the info, I need to check that out once I get cought up with work.
/ Ordering 3520 have a question #47
Whoops, looks like I misread:eek: I had a 3120 before my 110, and it had the 60" bucket. His 3320 with cab will be more equivalent to my OS 3120. No way would I be getting full loads of gravel with that size bucket. My 110's bucket is a 72"! There are plenty of times when it's working hard with that size bucket and it's a much larger more powerful machine. Unless all your doing is light material (snow/sand MAX) I'd get the smaller bucket. Don't take this the wrong way, just trying to help. But take a look at the buckets and size difference between the two. Picture doesn't really do it justice, but I'd be weary of the larger bucket.
My pleasure Brian. I'd like a 4 in 1 as well, and the Deere was the first choice for my 110 for OEM reasons, but sticker shock has me. Here's a well used one on eBay for $1,200:
JOHN DEERE 110 4 IN 1 LOADER BUCKET PART NUMBER LVB25343 | eBay
/ Ordering 3520 have a question #48
I agree on giving the bucket sizes a lot of thought and understanding what works well where...
So, there's a couple of things that I think are worth mentioning...
1) I think most first-time buyers (myself included) go with the premise that they want the largest bucket available, especially when they see that the price difference from one to the next is comparatively small.
2) Having the larger bucket tends to not be an issue because they aren't regularly using it to move *heavy* material (like gravel).
3) After using the loader for a while, you realize that you can't "fill" the bucket, so having a larger bucket that you partially fill will move more material in one pass. Plus, by not trying to fill the bucket, you end up with a manageable amount of material that you can move without spilling.
4) If you find yourself doing a LOT of loader work, get a second bucket and go smaller in size. Having the choice will end up being very helpful.
5) Having the larger bucket (read: wider) means we can drop the loader and drive... And clear a path that the tractor will fit through. And, for a lot of us, that's a need.
/ Ordering 3520 have a question #49
I understand where your coming from, but I respectfully disagree. After owning and operating tractors my entire life I can tell you what's going to work and what's not. A bucket that is larger than the width of the rear tires greatly decreases operating strength. Though the breakout specs are much better on the FEL of my 110, I use the BH because per square inch, there is more pressure to uproot a stump because of the smaller bucket size. I still would like smaller buckets than what I've got, like a 6" trenching bucket or even a ripper as will put the pressure in a more concentrated area. If I need a larger bucket, I'd buy a larger tractor.
/ Ordering 3520 have a question #50
I completely follow, understand, and agree with the examples you're giving. At the same time, they give me reason to not include you in groups like "first-time buyers" or "most people". Your experience with the machines and the variety of ways that you use the bucket specifically give you a tremendous amount of perspective for those of us that haven't / don't use the machines in the same ways. And that makes your comments valuable.
I was attempting to add to what you were saying by pointing out *why* so many of us go with the larger buckets, thus giving folks even more food for thought when making their own choices. If one knows the point AND the counterpoint, they can see both sides... And, for me, that means I will usually make a better-informed decision of my own.
/ Ordering 3520 have a question #51
My 2520 comes standard with a 53" bucket i upgraded that to a 61" and it handled it fine. yes you cant fill it with wet sand or gravel.
Reason i went with a 73" bucket on the 3320 Cab is because i move snow with it. I also use it for moving lots of other lighter items from mulch to other random lighter things.
The larger bucket is terrible for digging though. and for moving rock i can simply take smaller scoops at a time vs buying two buckets for the tractor.
For digging holes in the ground i'll use a skidloader. So i guess for me personally and it's to each their own i went larger loader thats wider than the tractor and than control the weight i'm loading but not over filling the bucket if its something dense. Kind of the best of both worlds not great any either but ok at both
/ Ordering 3520 have a question #53
I have the 3520 with the larger bucket. I wish I had the smaller one. For me it tends to just stick out to far on each side and becomes a PITA when manuvering in tite spaces. Also start thinking about ballast. I loaded the tires and put 1k pounds behind it when moving large bucketfulls of material. Wish they made a size inbetween the two bucket options.
I'm guessing down the road i might pick up another 61" bucket for the smaller tasks. i agree on ballast. Cab does add a lot of weight but i'm also getting the tires filled.
I have a box blade that i've loaded down pretty good that also helps for ballast.
This waiting for it to be built is killing me haha.
/ Ordering 3520 have a question #55
The other thing you have to consider is the volume of the bucket. The 110 is a deep heavy bucket, if I remember correctly 1/2 yrd flat or 5/8 yrd heaped. The 73" they are talking about is a 1/3 yrd or less. The difference can be 500 lbs for heavy material. I find the 110 needs an 84" 1 yrd bucket for loose/lighter material. For digging in dirt and stone, the 72" is perfect.
2015 FREIGHTLINER CASCADIA T/A 6X4 SLEEPER TRUCK TRACTOR (A59908)
2015 FREIGHTLINER...
2022 Caterpillar 906M Compact Articulated Wheel Loader (A56857)
2022 Caterpillar...
4021 (A59228)
4021 (A59228)
2016 Ford F-150 Crew Cab Pickup Truck (A61568)
2016 Ford F-150...
2014 International DuraStar 4400 Service Truck with Crane, VIN # 3HAMKAAN0EL771639 (A61165)
2014 International...
2012 JACK COUNTY TANK 130 BBL STEEL (A58214)
2012 JACK COUNTY...
