Lime, crickets, and tomatoes
/ Lime, crickets, and tomatoes #1
MikeA57
N. Mississippi
Ford 1510
Two unrelated questions here concerning my tomatoes. I was experiencing bloom rot on my tomatoes when they started coming in and I was told to put Lime down around the plants and work it into the dirt. I put what I thought was a good amount but not too much and now we've had several days of pop-up showers around the area and the tomatoes are really starting to ripen up and come in. But when my wife and I went out to pick last night, I know that we threw away more than we put in the bucket because of bloom rot. I put the lime around the plants this past Saturday and I know that it's not going to fix the problem in an hour but, how long does it take the lime to work into the plant and reverse the bloom rot? Do I need to put another dose down? Or just sit back and be patient? This is my first garden so I'm very new to all of this.
And then, I never knew crickets could be so destructive or so ravenous! They have really been doing a number on my tomatoes and my cantaloupes. I threw 5 or 6 tomatoes and 1 cantaloupe away last night that had been eaten by crickets.
So, how do you get rid of them in your garden?
/ Lime, crickets, and tomatoes #2
Tomatoes usually like slightly acid soil (ph 6.0-6.5)so the lime may not be the answere. It's best to check the PH and then adjust the soil ads required.
Blossom end rot may be caused by too much water or cycling between too much and not enough which effects the calcium uptake. Too low a PH will also affect calcium uptake.:thumbsup:
Straight from a Google of
"Blossom end rot".
/ Lime, crickets, and tomatoes #3
<snip>
Just to clarify: are these crickets or grasshoppers?
/ Lime, crickets, and tomatoes #4
As Egon said water has a lot to do with end rot.
Also the lime is good but needs to be applied for best results at or before planting. You can get a calcium spray for the tomatoe they may help. I buy calcium chloride in the 50lb bag and sprinkle it around my plants. It is absorbed more quickly by the roots. Check with your local farm supply to see what they carry.
If it is calcium in most cases the fruit that is set will be affected. The new fruit with proper calcium and water should be fine.
They're Crickets. Big, fat, black crickets.
And, I'm getting ready to send some soil samples into the Extension office to put some food plots on our hunting land so I'll make one up for the garden as well.
Thanks guys!
/ Lime, crickets, and tomatoes #6
As pointed out blossom end rot is typically caused by a calcium deficiency due to the lack of water or fluctuations in watering. It’s a common problem, and tough to deal with.
The lime you put down won’t help your current set fruit. It should help future fruit that has yet to set. Next year be sure to add the calcium when you plant and it should help thwart the problem, although BER can be a bugger to avoid.
/ Lime, crickets, and tomatoes #7
I am breaking up some sheet rock and incorporating it into the soil around my plant thet have BER..Only three plants have it...I am also adding Epson salt to the water I pour into the PVC tube at the roots of one of the plants..Early girl and Better Boy plants do not have it yet..We just had rain after a couple dry weeks, hence the watering of the roots.
/ Lime, crickets, and tomatoes #8
Thanks guys!
That's just wierd. We never see crickets in the garden. Lots of hoppers, but no crickets.
/ Lime, crickets, and tomatoes #9
We don't have any grasshoppers or Crickets, I GUESS the Squash bugs ate all of them...I am really getting fed up with them. the third year in a row, for this squashbug infestation...I am going to burn the field next to my garden this fall to try for some relief..
/ Lime, crickets, and tomatoes #10
You guys are lucky; I have blight on my tomatoes.
/ Lime, crickets, and tomatoes #11
Next year when you plant your tomatoes, but some bonemeal in the hole to take care the blossom end rot.
/ Lime, crickets, and tomatoes #12
Tomato tone has saved my as*
/ Lime, crickets, and tomatoes #14
As for the Blossom end rot, I'd not be too anxious to add lime before taking a PH reading of your soil. My soil is naturally slightly above 7 and I don't need to raise the number by blindly adding lime. As has been said, you can't do anything to correct the current crop that is displaying blossom end rot.
/ Lime, crickets, and tomatoes #15
Didn't know you could overwater tomatoes. Aren't hydroponic tomatoes grown with the roots suspended in water?
/ Lime, crickets, and tomatoes #16
I have had blight on my tomatoes every year I have grown them. The leaves slowly turn brown and fall off, working their way up the plant. I don't worry about it though, because they still make more fruit than I know what to do with.
/ Lime, crickets, and tomatoes #17
I think that it's not so much overwatering as uneven water. If you give the tomatoes a sudden rush of water after they have started to set fruit, the fruit can split or rot. I have heard it's best to water them heavily until they start to set fruit, then go a little easy. Of course, you can't control the rain. We have had five inches of water in the last two weeks here (after three or four weeks of drought), and I am concerned for my tomatoes.
/ Lime, crickets, and tomatoes #18
Thanks!
/ Lime, crickets, and tomatoes #19
If calcium at a low level then fluctuation of water causes the tomato plant to speed up growth and use up the available calcium and then the cell formation in the fruit is compromised and you get blossom end rot. Sheet rock has calcium in it but can also some what elevated heavy metals and other other chemicals. Epsom salt is a good quick calcium supplement.
New/Unused CFG Industrial H15R Mini Excavator (A65583)
New/Unused CFG...
2023 John Deere FC15M Batwing Mower (A66285)
2023 John Deere...
Small Gun safe (A64557)
Small Gun safe...
2018 Nissan Frontier Ext. Cab Pickup Truck (A64556)
2018 Nissan...
(2) INTERNATIONAL FERTILIZER DISTRIBUTORS (A64278)
(2) INTERNATIONAL...
2007 FREIGHTLINER COLUMBIA TANDEM AXLE 6 X 4 TRUCK TRACTOR (A67147)
2007 FREIGHTLINER...
