MX5100 fuel usage
/ MX5100 fuel usage #1
rthrbhntg
Delaware Co NY
Kubota MX5100
I'm new to owning a tractor and just bought a new mx5100. Most of the tractor usage has been using a tiller or a 6ft brush hog. We have 10 hrs on it and have used over 20 gal of fuel, Does this make sense?
/ MX5100 fuel usage #2
Yes it does. That's some hard work with the engine tach'd out pretty good.
I generally average 2 gal per hour bushogging and about 1 gal per hour for loader work.
/ MX5100 fuel usage #3
Yep, mine sucks down more hogging and tilling than loader work also. 2 gal/hr is a normal amount
/ MX5100 fuel usage #4
Agreed, I use about a gallon per hour for loader work which includes some idling.
/ MX5100 fuel usage #5
I was brush hogging last week for 5hrs and used 7gal running in MED at 540pto
/ MX5100 fuel usage #6
Not to take away from the original question but have you guys noticed if your guage is reading correctly? I think mine is about a 1/4 off
/ MX5100 fuel usage #7
Mine's off by about that much too. When the gauge indicates that I have somewhat less than a half tank remaining (40% remaining?), it only takes 5 gallons to fill it.
BTW, I love this tractor.
/ MX5100 fuel usage #8
So is it normal for the gauge to be off? I mean when you spend thousands on a tractor shouldn't the gauge read correct?
/ MX5100 fuel usage #9
And further off course-- Some folks have characterized the MX5100 as "fuel hog". Seems to me that I can get a heck of a lot done on 5 gallons, which is less than $20. What do you think?
/ MX5100 fuel usage #10
I don't care about it too much now that I know about the error, but yes, when you consider the amount of engineering that went into the engine, transmission, or even the loader geometry, you'd think they could get the fuel gauge to read correctly.
/ MX5100 fuel usage #11
my kubota sipps fuel no matter what im doing with it.but you have to remember im used to dealing with bigger farm tractors.
/ MX5100 fuel usage #12
Yep, mine is off also. The good thing is I alway have more fuel than it shows.....
/ MX5100 fuel usage #13
I dont have a mx5100 but it was on my short list... my L5740 is a fuel hog too in my opionion comparing the same work to my old mf35 its about twice the fuel burn for same tasks. I'm disapointedto say the least.
/ MX5100 fuel usage #14
1-2 gallons an hour? Wow! Both my Kubotas are 2-3 hours per gallon and the old L3750 is a 5 cylinder and 3900 lb.
Gear drive here and usually not running over 2000 rpm. Could the high fuel usage of the MX5100 be a HST thing? Or do some of you have gear drive?
I ask because I'm going to replace the 3750 at some point with a larger machine.
/ MX5100 fuel usage #15
I'll bet if you look at your tank it is an irregular shape which makes getting a totally accurate reading from a float type sender almost impossible.
/ MX5100 fuel usage #16
I average 1-1.5 gallon per hour for overall usage. That includes everything from cutting grass and brush, pushing snow, moving dirt, grading, pulling logs, hauling firewood, pulling trailers etc...
I am rarely over 2k rpm unless running the pto. Mine is gear drive.
/ MX5100 fuel usage #17
Thanks for the info! The MX5100 gear drive is one I'm considering.
/ MX5100 fuel usage #18
The work that most folks do with a small tractor like the MX5100 of L5740 is really variable, so fuel consumption will vary.
When bush hogging, the grass isn't usually consistent thickness, when rototilling, there is generally a lot of stopping and starting, when doing loader work, it is generally not heavy load on the engine. It is no different than having an MPG range on a car. For $20 you can get a lot of work done.
/ MX5100 fuel usage #19
heres something that i just thought of.if you want to know what it cost to run or how meny gal of fuel you use do this.take the gal you use in a day an devide by hours worked.then times the cost of diesel to gal used in an hour.i usually dont worry about how much fuel i burn.
TEREX RL4 LIGHT PLANT (A63569)
TEREX RL4 LIGHT...
2016 Dodge Charger Sedan (A59231)
2016 Dodge Charger...
Arrow Quip 10' Bow Gate (A64047)
Arrow Quip 10' Bow...
2019 John Deere 1775NT Planter (A63111)
2019 John Deere...
2019 KENWORTH T680 T/A 6X4 SLEEPER TRUCK TRACTOR (A59910)
2019 KENWORTH T680...
1995 John Deere 7400 (A60462)
1995 John Deere...
