Homemade Mini Firewood Processor
   / Homemade Mini Firewood Processor #1
ferguson123
massey ferguson
found this on youtube and just thought i wood share as it is a great wee project and idea
   / Homemade Mini Firewood Processor #2
I'm not too enthused about the unguarded chain running right next to
the exposed left arm. One slip off the handle and a really big OOPS!!:shocked:
However, the general idea is clever.
Bill
   / Homemade Mini Firewood Processor #3
Yikes, the hands and arms seem too close for comfort. I would design it in a way to be protected and further to the chain. But seems like a good start to a design.
   / Homemade Mini Firewood Processor #4
Almost seems if the saw was reversed it would make more sense/be safer?
You would need to pull up instead of push down but much safer
   / Homemade Mini Firewood Processor #5
I think this should be designed to include a safety housing the bar would go into when not cutting. Then the lever to move the saw should be extended so the grip is over a foot away from the cutting bar. Until then, I wouldn't consider using it. But then, that's just me.
   / Homemade Mini Firewood Processor #6
What if we made one with a rubber blade? That would be safe??? :)
   / Homemade Mini Firewood Processor #7
I grew up in a farming area and knew lots of adults with missing fingers, toes, etc. Sometimes you can be just as quick and efficient and still be safe. I think this device falls into that category.
   / Homemade Mini Firewood Processor #8
Hi all
He may be very adept at making things but designs like this are more likely to kill or maim. In this design you are pulling the blade towards you and unless you awkwardly stand to one side there is a good possibility of the tip of the blade catching the front of your loose shirt and in your pulled. It's a stupid and dangerous design.
Mike
   / Homemade Mini Firewood Processor #9
I agree.
Great firewood processor but does look unsafe with being that close to the chain. I sure wouldn't use it. I think I wanna keep my arms.
Chad
   / Homemade Mini Firewood Processor #10
Just thinking a little more about it, this could be modified to have a "fence" with an opening for the wood to be pushed through. Then the saw could be operated by a foot pedal below the table, not a lever above the table. That way the operator could be shielded from the blade and could use both hands to move and hold the wood.
Oh, why stop there? Add a hydraulic lift, rollers on the table and BIG saw. :licking:
   / Homemade Mini Firewood Processor #11
Great idea. :)
Chad
   / Homemade Mini Firewood Processor #12
Around here, that's not firewood, that's kindling....
   / Homemade Mini Firewood Processor #13
Useless & dangerous. No thanks!
   / Homemade Mini Firewood Processor #14
If the pull handle was off set away from the blade would help as well, and some type of stationary guard that the blade went up into when not sawing would be a big help, I think I would want a piece that the nose of the saw bar would be guarded as well.
or make a foot peddle to step on and pull the saw through that would leave both hands free,
It could have the switch incorperated with it so the first inch would turn on the saw and the remander would pull it throught the log, or limb, and it would auto shut off as well, maybe in such a way that if the foot was released it woudl shut off regardless of the postion of the saw, (possibly a foot switch on a bressure bar, to move the saw,
   / Homemade Mini Firewood Processor #15
This guy is crazy. I would redesign and like others have said make if foot operated or add an actuator also. Add a guard for that bar
   / Homemade Mini Firewood Processor #16
How is this any more dangerous then just using a regular chainsaw? You guys are WAY to quick to condemn, not saying there couldn't be a guard here and there but overall this is just as safe if not safer then running a regular chainsaw into small brush like that. "Kick back" with this setup might hit a finger or hand, "kick back" with regular sawing would result in loss of facial tissue. Yes I do cut wood, have for over 30yrs. also own a sawmill, so no I'm not green when it comes to chainsaws nor logging. This design is not all that bad and if it works for him I don't see an issue. No matter how many safety devices are forced onto us through self save laws, there will allways only be one true safety device that'll do the most............operator knowledge. Seems to me this person has made something that makes life easier for them and IMO didn't do all that bad. Okay I'm done with my observation back to all you recliner chair pros.
   / Homemade Mini Firewood Processor #17
It is different than using the saw only because when you are doing so you have both hands controlling the saw and wearing cutting helmet, shield and boots/chaps (I take it you wear none of the above)
Oh excuse us for trying to save the guy from dismemberment and life changing injuries.
I guess your not a man if you utilize safer equipment that could work just as well if not better than the original design...
I for one need my fingers, hands, toes and arms for my livelihood and career.
I am no logger but have cut for many years with chainsaws, quick cut saws and numerous other power tools (I guess that makes me an armchair quarterback because I don't earn a living doing it; so be it!)
You can be productive while being safer!
   / Homemade Mini Firewood Processor #18
As I said before, it's just me, but guns and chainsaws have two ends and I know which one I want to be on.:thumbsup:
   / Homemade Mini Firewood Processor #19
In this guys defense, it appears that the camera angle makes it look like the saw is much closer to his hand and arm than it actually based on the opening shot. Still makes me cringe though and I don't want to run it.
   / Homemade Mini Firewood Processor #20
Did you watch the video he has his safety equipment on :rolleyes: Your idea about 2 hands versus a solid pivot shaft and one hand is basically showing you either did not watch the video or just plain don't understand the workings of a saw. To answer your question yes I do wear safety equipment, thanks for your concern.
You're not trying to save the guy from anything, instead your just cackling like a bunch of old hens at a "burn your bra convention"
I quess your not a man unless you whine about everyone else, pass judgement and criticize everything
I'm sure most of us do, so what's your point? I didn't see any body parts fly off!
Nope that doesn't make you an "armchair quarterback" but your b***hing about anothers ingenuity and productivity does :D
If you noticed my post, I wrote it could have some extra shields etc... But I still say it seems fine as long as someone with common sense uses it. Still would say it is a safer setup then a regular chainsaw. But hey what do I know, according to you I cut wood while naked and feel that real men would only use 1 hand! Now if I could just keep those black flies from bitting me in the arse............
2020 DRAGON ESP...
20 LOWBOY BUMPER PULL TRAILER (A55745)
20 LOWBOY BUMPER...
PALLET OF (3) INDOOR CABINETS (A60432)
PALLET OF (3)...
2011 FORD F350 SERVICE TRUCK (A52707)
2011 FORD F350...
AUCTION STARTS HERE @ 9AM (A60429)
AUCTION STARTS...
2014 AMERITRAIL LAY FLAT HOSE TUGGER TRAILER (A58214)
2014 AMERITRAIL...
