Road Travel?
   / Road Travel? #11
I am not sure how your cruise control works but my cruise is just a simple electromagnet that holds the hyrdostat in a stationary position. Any extra load, like going up hill, will cause more strain on the motor and slow the RPMs down slightly.
   / Road Travel?
The rpm drop got to be a real problem on the return trip. 2 hours to go 9 miles. 6 miles of the trip run by a river and the only significant climb is to cross a railroad overpass. Very gradual 1/8 mile. After the first ~2 miles rpm's dropped, I eased the hydro pedal and they recovered. There's no doubt this was on the flat. Zero incline
But now it got interesting. At first I thought the hydro was doing something strange so I pulled into a lot and checked everything - oil levels good, confirmed not in 4wd, parking brake ok. Everything was ok. Coolant temp on the gauge never left the mid-point. Restarted the journey and it got progessively worse to the point where I had to stop and let the engine recover, but as the trip continued the engine would 'hunt' - rpm's would recover to 2800 then drop to as low as 800 then back to 2800 - during these rest phases.
I kept moving since I wasn't going to leave the tractor by the road overnight and it got to the point where the engine would stall during the rest phase. It restarted immediately but this was really frustrating since by now I was making 100ft legs on the last couple of miles. Well, really short runs.
Finally made it home and with my neighbor's help we deduced what we think was the problem. Ruled out hydro becasue of the hunt while standing in neutral with clutch in. Had to be either fuel or air. Fuel seemed unlikely since the engine would restart right away after stalling - no hesitation or cranking. That left air so we pulled the air cleaner for inspection which was apparently perfect, no birds, rocks, sand, dust.
Then we noticed that the actual air intake is a small diameter hole - maybe an inch - that had a rubber cone with a narrow slit for air to pass through. A shipping cone?
Yesterday was one of the hottest so far this year, mid 90's, and I think the rubber heated to the point that the engine could suck it closed, then when the rev's dropped it expanded to let more air in. I'm guessing it's an item the dealer forgot in prep.
   / Road Travel? #13
Does the air filter look like this:
If so, the pointy thing on the bottom left (in the picture) is not the air inlet, rather it is a dust catcher and that should let you dump whatever dust it has collected without needing to open the filter
Aaron Z
   / Road Travel?
Yeah, after I posted I looked at the manual and then the tractor and it was a 'duh' moment. Kioti calls it an "evacuator". It's on the opposite end of the canister from the intake.
Can you tell it was in the 90's and I was frustrated when I guessed at my problem?
   / Road Travel? #15
Dust? I think that's a drain for water. Some of us have been known to try and drown our tractors, so having a water dump on the canister keeps the engine from breathing water, since that is the lowest point on the filter canister.
Bherr it sounds to me like it could be a fuel delivery issue. Take the filter off clean it or replace it. Then dump a quart or two of Power Service in the tank. But since it's brand new, I think I would just have my dealer take a look at it.
   / Road Travel? #16
You do remember you just filled the tires. Anything with added weight is going to run slower than before and I think you indicated it was mostly downhill to get the tires filled so that means it was uphill going home and with more weight!!
   / Road Travel?
Dealer is scheduled to look at the punch list next week. Trivial stuff except for the rpm's deal. He suspects fuel issue also. Fuel filter looks "twisted" but I'm not sure if that's normal or not. I suspect not.
Added weight certainly affects tractor's performance but this was ridiculous. Tractor's move slow and so you get to see and smell everything, but you're not supposed to stop so you can proceed. Especially near road kill in the brush when it's over 90
What and where is Power Service? Similar to Sta-Bil for gasoline?
   / Road Travel? #18
Completely valid point, but how would that explain the "hunting" the motor was doing while it was sitting still?
   / Road Travel? #19
Yep, very similar except for diesel:
DIESEL KLEEN® +Cetane Boost®: Max HP Formula ? use during non-winter months for the ultimate in performance.
I have a 300 gallon storage tank and once a year when it gets filled up I add a gallon of Power Service and a proper dose of biocide to kill the bacteria that likes to grow in the water that ends up in the diesel from the large tank sweating. Most service stations stay on top of all this, but you never really know what "extra's" you might get free of charge:eek:
   / Road Travel? #20
Awww, I didn't read that very well did I? That shouldn't have anything to do with that. Does that fuel filter have a site glass? I'm assuming it does or he would not be able to see the twist. If he had lots of condensation and has some water in the fuel it would do that. Also if it was plugged but I wouldn't think that would be so. He could have just gotten some bad diesel too. It happens. We had a problem at work for quite some time and come to find out it was an algea problem. Don't ask me how but that stuff will grow in diesel. They used something to kill it out and filtered the fuel as it came into the storage tanks and as it went into the fuel truck. It took a little while but we finally got rid of the problem. I'd have to change a fuel filter in the bulldozer every 100 hours. Now I can go 250 or more but we change it when we change the oil now days.
2016 KOMATSU D65PX-18 BULL DOZER (A58216)
2016 KOMATSU...
2025 Swict 84in Bucket Skid Steer Attachment (A56857)
2025 Swict 84in...
John Deere 853 20ft Corn Head (A56436)
John Deere 853...
Ford E-350 Passenger Van (A56858)
Ford E-350...
Kuhns AE10 Small Square Bale Accumulator - 10-Bale Efficient Handling System (A56438)
Kuhns AE10 Small...
Amada M-3060 Mechanical Metal Shear (Japan) (A59213)
Amada M-3060...
