Best heavy duty rear blade ?????
   / Best heavy duty rear blade ????? #21
+1 on the gage wheels. Makes a huge difference. My blade is a 10' all hydraulic Bison NVHL300.
Kim
   / Best heavy duty rear blade ????? #22
Schmism, do you have or have you ever used a (driveway scraper blade) ?
Anyone that has very much of a drive or road to maintain, I usually suggest that they have more than one implement to take care of that chore. That is why I have 4 different implements to do the job, each one is better than the other for an intended purpose. ;)
I have to admit to never useing one.
As to the second part, you couldn't be more wrong. I use a singular example as evidence to support the idea that the best item (and perhaps only item) needed is a rear blade, is the fact at all rural counties have used a singular item to maintain there gravel/dirt roads for the past 100+ years. That item, a motor grader.
While a rear blade is no motor grader, its the closest your going to come to a MG.
As to useing a LandPlaneGraderBlade, dirt/gravel roads move with seasons. espeically in the wet seasons and durring frost thaw. Once the perfect shape of a road has been changed from both weather and travel, the only way you can effectivly reshape it is useing a rear blade. Yes you might get it done with a box blade, or even a LPGB, but when your talking 9 miles of road to maintain I think the OP is going to want to only consider options that get the job done with as little time and as few as passes as possible.
The fact that a LPGB is not designed to allow crown to be built into a road, you can not reclaim loose material that has been driven to the edges of the road by traffic with a LPGB and you cant cut ditches with it. You cant windrow material with it, and it is of a fixed width limiting use on roads with various widths, such as around turns and between obstacles.
see Smoothing and Reshaping of Earth and Gravel Roads - YouTube for great instruction on how to reshape and resmooth gravel/dirt roads useing a MG. Essentially the same process with a rear blade. All of the options discussed, side shifting the blade, blade tilt for mixing of larger and small aggregate, blade angle, wind rowing. A rear blade is the ONLY implement that can do it all.
I believe LPGB's have become so popular is because they cost less than large HD blades, and are easyer for the avg homeowner to use to maintain there own gravel driveways. (hook it up, pull it behind the tractor, instant results. nothing, and i mean nothing to adjust) But make no mistake, a gravel driveway use is far different than the expectations of gravel road use, because of that and the above points, I just dont see how recommending a LPGB for road maintenance over a HD rear blade makes sense.
   / Best heavy duty rear blade ????? #23
I maintain 2 1/4 miles of road. 1/2 mile is a shared road with 6 lots using that portion. I agree that for heavy use roads, and you could only have a single implement, that a rear blade is probably the way to go and once a person gets good with it, you can get by with it just fine.
You think that the LPGB is used without doing any adjustments, you couldn't be more wrong. Yes people that don't know what they are doing use them in that manner. People that have an understanding of how they can work are able to do many many things with them. Far more than what they accomplish by just hooking up and dragging them around. You think that I don't know what I'm talking about, why do you think that I have a my Land Pride RBT45108. It's for my roads and to build new roads.
I believe that you suggested a big expensive hydraulic rear blade, but then said that for how much that they cost you might as well buy a motor grader. Were you kidding about that? I would not want anything to do with a motor grader that cost 4-5 grand. You would have nothing but a big piece of scrap metal for that kind of money, around here anyway.
Something that we both need to remember is that conditions vary widely and what each of us have been talking about obviously are different between each of our areas and unless you personally know the OP, his conditions and circumstances may be completely different than what we may be use to.
Good luck to the OP and I recommend multiple implements to get the best results possible. ;)
   / Best heavy duty rear blade ????? #24
5 pages of MG's between $5-$10K most of which are much more than a piles of scrap. http://www.machinerytrader.com/list...x=contains&bcatid=4&Pref=0&Thumbs=1&scf=false
   / Best heavy duty rear blade ????? #26
love our 8 ft Rhino that we pull with out 70HP tractor, tho it is a much older model. If I were to buy another blade I wouldn't get any other brand. Great HD blade.
RHINO | Born to Lead | Agricultural, Industrial, and Commercial Equipment
RHINO | Blades | Heavy Duty Rear Blades
I can attest to the durability of those Rhino blades...
We have an 8' that my dad bought many years ago when in the tractor business...
It is heavy duty and can be tilted and angled at the same time...
At the time it was one of the best units Rhino made...
Excellent product...
   / Best heavy duty rear blade ????? #27
I don't own it anymore traded it towards new disk harrow but here's pic's of my-x "Little Rhino" . They started making these in 1958 back when Servis/Rhino was in the Lone Star(Dallas). Check out the design of top link connection.
Boone
   / Best heavy duty rear blade ????? #28
This is my Land Pride RB3584 , as you can see it's quite heavy duty. I had a RB1572 before and believe me there is no comparison.
DevilDog
How well does the 3540 handle that blade? I'm interested as I have a pretty similar sized tractor.
About the replies so far, some great ones and great suggestions, however, the OP has stated that he is interested in a HD rear blade, so he doesn't have to bring his EXCAVATOR and DOZER to the land. He is using it on a 100hp tractor. Forgive me if I'm wrong, but he doesn't strike me as the kind of guy who doesn't have a clue about what is best for him? Obviously the suggestions are always welcome, to an extent, but if he is interested in a HD rear blade, is maintaining a 9mile stretch of gravel road, and is using some seriously HD and expensive equipment, he probably knows what will work well for his purposes. He's not another one of us CUT tractor owners with 500' of driveway to maintain who barely knows how to hook up his box blade.
   / Best heavy duty rear blade ????? #29
I have both a heavy duty blade, 96", and a heavy duty Cammond grader, 108". I would disagree that the grader is not designed to allow crown to be built into a road. At least for the Cammond unit it has the adjustment to specifically do just that if that is what is wanted. Additionally it does a very good job of reclaiming loose material on the edges of the road. (it will not reclaim it from the bar ditch, only the blade will do that) Agree you can't cut ditches (at least very well or deep) and it does not do a good job of windrowing material but it is no more limited as a fixed width than the blade is except the blade is 96" and the grader is 108" both can do roads of varying width depending upon how they are used.
   / Best heavy duty rear blade ????? #30
2020 PETERBILT 567 (A58214)
2020 PETERBILT 567...
2011 John Deere 855DXUV Gator (A57149)
2011 John Deere...
IRanch High-End Mini Golf Cart (A57149)
IRanch High-End...
2019 CATERPILLAR 289D SKID STEER (A52709)
2019 CATERPILLAR...
2016 WESTERN STAR 4900 SB DAY CAB (A58214)
2016 WESTERN STAR...
2014 Chevrolet Silverado 1500 Pickup Truck (A55973)
2014 Chevrolet...
