Since we all know FEL's are not built for pushing like a dozer . . .
/ Since we all know FEL's are not built for pushing like a dozer . . . #1
RealJimbo
has anyone designed/built a FRONT dozer blade that attaches to either the 3pt arms on the frame/axle housing?
/ Since we all know FEL's are not built for pushing like a dozer . . . #2
I had a sub-frame mounted front plow,for snow...on a L3130 Kubota..don't think it would have moved dirt very well.A larger tractor may-be....
/ Since we all know FEL's are not built for pushing like a dozer . . . #3
install a toothbar, and it will preform like a dozer!
this is what i did.
accordionman
wright city, mo. L3000DT
/ Since we all know FEL's are not built for pushing like a dozer . . . #5
Do you have a good heavy box blade already? I've been doing lots of "bulldozer" work with mine and was thinking how annoying it would be just to have a single bulldozer blade... Also without rippers to break up the soil, it doesn't take much of a rock to stop my tractor when I do push with the loader even with Ag's, loaded rear tires and 1100lbs of box blade. All having a dozer blade on the front would do is allow me to carry a bit more speed to help pop the smaller rocks but it would still be a sudden stop on big ones.
/ Since we all know FEL's are not built for pushing like a dozer . . . #6
Careful now. The 3-pt. is not designed to push. It is designed to pull.
/ Since we all know FEL's are not built for pushing like a dozer . . . #7
A number of us have adapted a 3 pt quick hitch to a quick attach plate. As you see in my pic, this makes mounting a rake very convenience. I suspect a 3 pt blade would mount as well (I don't have one).
David Sent from my iPad using TractorByNet
While I agree with that statement, what I envision would still be 'pulling' from the 3pth lower arms. Pushing with the arms is what people do that push with the box blade/back blade/rake.:thumbdown:
My thinking is that the 'arms' of the front blade eith mount to the rear axle, or go all the way under the tractor and attach to the 3pth lower arms.
The Degelman is what I have in mind, but BIY and possibly a flat moldboard for dirt, instead of curved for snow.
/ Since we all know FEL's are not built for pushing like a dozer . . . #9
None are flat, they are all curved to a degree.
A flat blade will stop you dead in about 6 to 8 feet, due to the dirt piling up and compacting. A curved blade will roll the dirt(or snow) out in front of you. Snowblades are curved more to allow 'throwing' of the snow.
/ Since we all know FEL's are not built for pushing like a dozer . . . #10
John Deere sells/sold one that the back mounted to the front end of the drawbar. IIRC it was model 624 and 8' or 9' wide, had mounts from the front frame area and cylinders to lift it. Angle was manual.
2020 PETERBILT 567 (A58214)
2020 PETERBILT 567...
2018 ADDCO ROAD SIGN DH1000-ALS (A60736)
2018 ADDCO ROAD...
New/Unused 2025 CFG QK18R Mini Excavator (A61166)
New/Unused 2025...
2006 iDrive TDS-2010H ProJack M2 Electric Trailer Dolly (A55853)
2006 iDrive...
2016 PETERBILT 389 FLATTOP (A60736)
2016 PETERBILT 389...
2017 FORD F-350 XL 35' NON-INSULATED BUCKET TRK (A59823)
2017 FORD F-350 XL...
