Comparison kubota 5100mx
/ kubota 5100mx #1
case245
pa
kubota 7040sud
IS the kubota 5100mx based on an L series frame or is it based on an M SERIES FRAME THE DEALER TOLD ME TRACTORS A MIXES ON BOTH THE M AND THE L SERIES BUT HE DIDNT TELL ME IT THE FRAMES AN L SERIES FRAME OR AN M SERIES FRAME I WAS THINKING IT HAS AN L SERIES FRAME I COULD BE WRONG
/ kubota 5100mx #2
Here we go again... :rolleyes:
Closer to a Grand L, than a Basic L... Look at the weight specs.
MX series is on MX chassis...
/ kubota 5100mx
BLUEGILL2 WATEVER I GOT THOUSAND OF HRS ON A TRACTOR CAT 943B CASE 580B
/ kubota 5100mx #4
My comment was based on all your other threads that appeared to be train wrecks.
Anyway, look at the weight specs. The MX5100 is 1100 lbs heavier than a L3800.
Also, the L4600 is built on a Grand L chassis...
The L2800, 3200, 3400, 3800 are basic L series.
/ kubota 5100mx #5
It's basically the same as my L4610 if I remember correctly. No more lift capacity both front and rear. I haven't compared measurements but it's a lot closer to an L and much less capable than a true M.
/ kubota 5100mx #6
5E vs MX 1.jpg5E vs MX 2.jpg5E vs MX 3.jpg5E vs MX 4.jpg5E vs MX 5.jpgThe MX is definitely not built on the M frame - whether it is on an L or a Grand L I dont know, but from the specs it looks like it is the Grand L. Attached are some photos of the MX5100 and John Deere 5055E which is assuredly a true Utility Tractor.
/ kubota 5100mx #7
What's the price difference???
The JD is much larger, but I like the looks of it! Some will find the compactness of the Kubota in that size range more useful, others not so much...
/ kubota 5100mx #8
Case245, have you looked at that Deere. It was bigger than I needed, but a nice tractor. The price was reasonable, if I remember correctly.
Bill
/ kubota 5100mx #9
I looked at the JD 5055E and the biggest reason I went with the Kubota was the price and the Hydro, I do more loader work than I do PTO. I wish I had the wieght and loader capacity of the JD though
/ kubota 5100mx
no luck at all notforhire i trading it in i dont know on wat yet an M SERIES I GUESS
KBH 1600 Gallon Water Trailer (A64047)
KBH 1600 Gallon...
2014 KUBOTA SVL75-2 SKID STEER (A64279)
2014 KUBOTA...
Used Landpride GR1525 Stump Grinder
Used Landpride...
2008 INGERSOLL RAND G240-191KW GENERATOR (A63276)
2008 INGERSOLL...
PALLET OF MISC METAL (A63745)
PALLET OF MISC...
2000 CATERPILLAR 988F WHEEL LOADER (A60429)
2000 CATERPILLAR...
