Hot Htd lines
/ Hot Htd lines #1
sugargrovefarmer
Sugar Grove
Farmall Super M
Hi Guys, How do I check the routing of my hyd lines, I have an external pump with a resivior tank, The control valve has an inlet,outlet and one other line, The fluid seems to get extremely hot. The line from the external pupm has a very small leak and the wet hose smokes it gets so hot, Any sugesstions?
/ Hot Htd lines #2
Are you talking about a PTO pump.
What kind of valve do you have?
You may be in the relief mode full time.
/ Hot Htd lines
/ Hot Htd lines #4
I see now.
You are operating a single action cyl.
You should get rid of all those water pipe fittings and use hyd fittings.
Most hyd pumps are external, and I thought this was an additional pump.
Is the SA cyl you are using working correctly?
Power up gravity down.
Do you have the fluid path corectly?
Pump to IN port, OUT port to tank, and one work port B to a SA cyl . Port A is plugged.
The port close to the relief valve is the IN port.
Put a hyd gage in the hyd system and check the pressure relief.
Is this correct for your tractor?
Hydraulics:
Type: Lift-All, transmission-driven pump
Pressure: 500 psi [34.5 bar] (early)
800 psi [55.2 bar] (late)
2007 Ford F-150 4x4 Ext. Cab Pickup Truck (A61568)
2007 Ford F-150...
John Deere 652R 52in Stand-On Commercial Mower (A56857)
John Deere 652R...
2020 CATERPILLAR D5K2 LGP CRAWLER DOZER (A62129)
2020 CATERPILLAR...
New/Unused Wolverine Quick Attach Trencher (A61166)
New/Unused...
2020 GMC AT4 CREW CAB TRUCK (A60430)
2020 GMC AT4 CREW...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
