New Ride is here; fun cut short
/ New Ride is here; fun cut short #1
1savoy
Gold Member
Oklahoma
B26, ZD323-60 and JD JX75 currently. Previous: L3800 HST w/ BH77, JD301-A , JD450C Dozer, JD 330, JD F525, Ford 4000, Farmall H
Well, I have been hanging around the Kubota forum for a little while. I am a John Deere guy, but the JD dealers I have tried in Texas sure are not what I am used to in Western New York. Still waiting to get quotes they promised me??? Anyways I now have two Kubotas and just one nice green push mower left. I am very found of JD Industrial Yellow also having a JD450C crawler and JD301-A in the past. Well the new L3800 showed up today. It was a longer wait than initially anticipated, 7 weeks and a day, but I was in no real hurry for it. Came from Barlow's and Brady seems like a great guy. I was able to save quite a bit compared to the local dealers, even the one I bought my ZD323 from a couple of years ago. Well it has been almost two and half years without a tractor and I am thrilled to have one again. I tried out the HLA forks on a pile of pine branches that possibly had a rattle snake in or near. Put the bucket back on and while putting the ratchet rake on, noticed hydraulic fluid spraying out a fitting. Shut it down and found a fitting very loose. Tightened it up and checked all the other fittings on the tractor. Fired it back up and heard the strain of the hydrostat. No fluid showing in the site glass. Bummer :( Had 0.2 hours of fun anyway. I have Kubota UDT around, but no Super UDT. I know they are compatible but my thoughts were to wait and get some Super UDT tomorrow. I guess I will start working on my projects soon and try to post some. Thanks to everyone on this forum for making it such a great tool for shopping and comparing tractors. Picture 030.jpgPicture 017.jpgPicture 038.jpgPicture 033.jpgPicture 034.jpg
/ New Ride is here; fun cut short #2
Very Nice, Man! Bummer about the fluid...
I love mine! :D
/ New Ride is here; fun cut short #3
1savoy,
Great looking machine. Hope it gives you much satisfaction over the years!
I'm getting one too; your situation has convinced me to purchase the UDT fluid for my 50hr. change on the day I get the tractor!
Thanks guys!! I think it will be a nice machine for many years and I am glad I chose this tractor. Overkill for my small place, but I guess I would not want a smaller machine than this from what I am used to. Familyman, I have been watching your threads but did not have much to add since mine was not here yet. The 38 hp seems nice for the short time I used it. Tires are loaded and the 66" bucket, plus BH. 32 hp probably would be fine, but I guess it is nice to have a few extra just in case. Ya, it is always good to have fluid around. I need to get some extra to have on hand for these occasions.
/ New Ride is here; fun cut short #5
Congratulations in regards to your new Tractor purchase. As you previously stated, it is always a good idea to have extra supplies around. I try my best to keep extra oil, fluids, and grease around, just in case. Best wishes and I sincerely hope that you enjoy many hours of Seat Time on your new Tractor.
/ New Ride is here; fun cut short #6
I was told that new Kubotas are shipped with UDT not Super UDT. Does anyone know if that is correct?
Bill
/ New Ride is here; fun cut short #8
Looks good. Great color!:thumbsup: Unless it has changed they ship with SUDT or the new SUDT. While your waiting will be a good time to check all fluids and bolts. I've found an occassional loose bolt over the years.
/ New Ride is here; fun cut short #9
Congratulations on your new tractor, as mentioned, always a good idea to keep fluids and such around. My dealer doesn't keep SUDT in stock, so it has to be ordered.
John Thomas, That is good info and I need to go over the whole machine. My ZD had the lower radiator hose rubbing the fan belt and after a few hours of use had antifreeze leaking all over. I guess I am two for two with Kubota leaks early on :) The ZD has been awesome since then as I am sure the L3800 will be.
TripleR, Now that you say that I do not remember seeing Super UDT at the dealer either. So I may just use the UDT I have on the shelf. The manual says they are compatible, what are everyone's thoughts? Probably does not make any difference at all which to use.
Bill
Good question?? I will try to find out.
Thanks everyone for the congrats. I appreciate it and look forward to being on the "Orange" side of things now. Funny how the green ones don't look so nice anymore!!!!
/ New Ride is here; fun cut short #14
Just thinking, the crated tractors would be dry, I would think. Maybe it's up to the dealer what goes in during the prep. I imagine that UDT is cheeper, and acceptable to use, so why would they (the dealer) put in SUDT?
Bill
/ New Ride is here; fun cut short #15
Up here in NY the dealer said to only use SUDT in the machine due to the cold weather. He said if just flows better under the cold temperatures.
/ New Ride is here; fun cut short #16
So maybe it varies dealer to dealer, depending on climate.
My last tractor was a HST. When I changed the trans fluid I went to Amsoil syn. It was much better in the winter. The syn. doesn't tend to thicken in cold weather like non syn.
My present tractor came from sunny NC, so they can most likely get away with standard UDT.
Bill
/ New Ride is here; fun cut short #17
I'd fire off a call to Barlow's and ask. I'd think UDT would be fine, and the fluid will get dumped after break-in in many cases anyway, but I would ask the guy you bought it from, since he knows more about it than I would, including and especially warranty issues if "oil x + oil y = Oil of Olay."
EE_Bota, Great minds think alike :) Already did that, but have not heard anything back yet. I know I will hear from him, he is very good at responding.
Hey Guys,
Do not think I have to worry about the cold weather here, but maybe on the other end of the temp spectrum. We will see what Brady says. Thanks again.
/ New Ride is here; fun cut short #20
Bill
I don't think they come dry to the dealer. I think the dealer gets them with fluids installed and are supposed to top them up. I also believe the ones from the south east warehouse (HSTs) come with the SUDT or they did before the new SUDT came out. Maybe a dealer will confirm or deny this.
