Hello
/ Hello #1
Bob V
Benton, IL
Kioti DK40
Hello everyone. I'm new this site and am looking forward to learning a lot from all you seasoned pros. I have a 2008 Kioti DK40SE HST (400 Hrs.) with FEL, Backhoe, Cab, and assorted implements. I use the tractor around home and to set cemetery monuments.
Again, looking forward to gleaning information from experienced people.
/ Hello #2
Welcome to the forums, there is a pretty active Kioti forum with lots of information on other general forums on equipment purchase, use, projects etc.
/ Hello #6
Hello. Welcome from Kansas.
Chad
/ Hello
Thanks for the welcome. Hope I can run a backhoe as well as you do.
/ Hello
Your close to Nashville, TN! That's a nice area.
/ Hello
You're in the American Farm Belt. Sure does get hot out there.
/ Hello #12
Welcome Bob
I think you'll find we're a pretty active community, so don't be bashful!
/ Hello
Thanks for inviting me to interact.
I have a couple of projects going. One is setting up a diesel fueling station. We have a Kubota RTV 1100 and a couple of kubota ZD331-72 mowers along with the Kioti tractor which are all diesels.
Would like to keep between 100 - 200 gallons of diesel on hand and have an easy way to fill the machines. If any one has built their own fueling station and it worked, I'd be interested hearing about the project. I haven't had much luck finding information on the net.
A second project is converting an old 3-motorcycle 2-wheel trailer into a flat bed. Think I have this one under control, but I am always interested in hearing ideas...
No man is an island and one can always learn from others.
2020 DRAGON ESP 150BBL ALIMINUM (A60736)
2020 DRAGON ESP...
TRANE AC / HEAT UNIT W/ AIR HANDLER (A63745)
TRANE AC / HEAT...
2004 TMP 32' T/A PIPE TRAILER (A63569)
2004 TMP 32' T/A...
iDrive TDS-2010H...
Mahindra 4550-4L Tractor with Front Loader - 49 HP, 4WD, Heavy-Duty Utility (A63118)
Mahindra 4550-4L...
2020 Hino 195 20ft. Electric Box Truck (A59230)
2020 Hino 195...
