Kubota MX500 Loader Not Lifting Unless Remote Engaged
/ Kubota MX500 Loader Not Lifting Unless Remote Engaged #1
Rawkis
Breslau, Ontarion
Kubota MX5000
Hi,
Just wondering if anyone can help us troubleshoot this issue.
We have a Kubota MX5000 with LA852 loader and only 500 hours on it.
We used the loader fine one day and the next it won't lift.
It will lift & tilt very slowly if we rev the engine a lot but can't lift any weight in bucket.
It will lift & tilt quickly with some weight in it if we engage the remote that has been installed by pushing the lever forward. Even with this it cannot lift a full bucket like it used to.
It was low on oil so we filled it up but hasn't made any difference.
We have checked what we understand to be the relief valves under the seat and on the front block and did not see any obvious issue with them - springs seemed fine.
I do have a service manual with Hydraulic circuit and service info if that would help.
Any suggestions on what the issue could be would be greatly appreciated.
Our local dealer doesn't know what it is and want's it in their shop to troubleshoot - they are a long way away and I'd like to avoid that if I can.
Thanks for your help.
/ Kubota MX500 Loader Not Lifting Unless Remote Engaged #2
Make sure the three point arms are not coming up to high . I have a mx5100 and for some reason when I was moving hay bales the three point was coming up to high .This would make the pump labor hard and the loader would not work right . Let three point down a little and all was find .
Thanks ford farm boy. This was what the dealer first suggested as well and we have tried the 3 pt hitch in various positions with no success.
/ Kubota MX500 Loader Not Lifting Unless Remote Engaged #4
If you have QD install in the system, recheck them, un-plug and re-plug. If the return to tank is blocked, weird things will happen.
If you have removed or switched hoses for any reason, recheck for proper location.
/ Kubota MX500 Loader Not Lifting Unless Remote Engaged #5
ford farm boy you can adjust your feed back lever and that well stop that.
/ Kubota MX500 Loader Not Lifting Unless Remote Engaged #6
Leejohn what is feed back lever and were is it ? this new to me . I just fixed the stop for the postion control at the top so lever will not go as far.
/ Kubota MX500 Loader Not Lifting Unless Remote Engaged #7
It's a rod that hooks to the upper lift arms and goes to a lever that goes to the 3pt valve. It was 2 adjusting nuts. On the MX5000 it's on the left side.
/ Kubota MX500 Loader Not Lifting Unless Remote Engaged #8
Ok Leejohn found feed back lever in manual . Thanks
/ Kubota MX500 Loader Not Lifting Unless Remote Engaged #9
I'd check the outlets! Unplug your hoses and connect them again.
/ Kubota MX500 Loader Not Lifting Unless Remote Engaged #10
Rawkis check the hyd. outlet block there might be a spool with a screw drive slot that you turn it for other hyd attachments. It might of got turned for some reason.
2016 AUXILIARY POWER UNIT (A60736)
2016 AUXILIARY...
SKLP SK-HJ6 40' 6 Section Storage Shelves (A60463)
SKLP SK-HJ6 40' 6...
2018 FREIGHTLINER CASCADIA 125 6X4 T/A SLEEPER TRUCK TRACTOR (A59906)
2018 FREIGHTLINER...
2018 FREIGHTLINER M2 4X2 26FT NON CDL BOX TRUCK (A59906)
2006 FORD F-450 XLT SUPER DUTY SERVICE TRUCK (A62130)
2006 FORD F-450...
1979 HEIL TRANSPORT TRAILER (A60736)
1979 HEIL...
