STEINER 440
/ STEINER 440 #11
At my workplace we sell Steiner and Ventrac. We got in our first 440 on May 22. This one has the 32hp. Kubota Liquid cooled gas engine. Now, I would definatly say it is beter than the 430, but over a Ventrac it is still hard for me to choose. The 440 only has a foot pledel option (although there is a hand-control option coming), I have to say I do like it. The controls for lift and aux are now like a Ventrac, on the right hand tool box. The unit is only a half inch wider, but a lot longer, and of course there are some minuses there. But it does turn tighter than the 430, so that helps. The gas tank is no longer under the seat, but is the left hand fender. On the right hand fender, the tool box is shallower, and the lower half hinges out to service the battery and hydralics. The hydralic pump and the head lights are somewhere around 50% more efficient than the 430. the attachment latch has been simplified with a hand lever instead of the push lever that dug into your hand with the spring loaded mechanism. the hydralic hook ups are also right at the front of the tractor so the hoses don't have to be run through anything.
I really can't wait to get it dirty. It mowes with a 6ft. deck with incredible ease over our big hills here. Weight distribution, which was a big issue with other units, has been over come with this tractor. You don't need any weights for the 6ft. deck! It really is pretty nice.
The only bad things are the foot pedel which takes a little getting used to. Also the steering wheel hits my knees when the unit is turned and osilating at a certain angle, but I am tall. And of course, the price. The 32 gas that we have is the highest priced model, at $21,900. The 25hp. Kubota Diesel is about $300 less, and the 34 and 40hp. Kohler air cooled uints are lower than that, but I haven't seen the exact price.
I would say if you have a dealer close by, go try one out! But remember if you get hooked, you might be a little in debt for awhile. :) Hope this helps you guys!
/ STEINER 440 #12
Looks like the new model 440 has alot of the features I want.Wonder what kind of price is on the 4 different engine options for the 440?Anybody else know any particulars? Eddie
The 32hp Kubota gas List $21,900.00, 25hp kubota diesel $21,000.00, 34hp air cooled $18,300.00 and the 40hp air cooled $18,800.00. Those are the list prices. We have retailed 4 units and have great results. The 17 gallons per minute with the new hydrolic system lets the engine do it's job and doesn't starve the pumps and motors.
/ STEINER 440 #13
The 22" increase in length will be welcome,the 420/430 was very tippy with the front end loader or 60/72" deck trying to go downhill and lift the deck for obstructions...i just hope it isnt at the expense of agility because thats one area the 420/430 really shined,they were good in tight spaces,and for getting around trees,especially the older 420s ,before they pulled oil from the rear diff,they steered really tight,the newer 420s had a hard oil pickup line running from the main pump to the rear axle in the way,it limited how tight they turned.I have 1 of each,the old one is a much better trim mower...As for the diesel, i think what it comes down too is space for the engine,with the way they set the engines backwards on the steiners and ventracs the cooling system is right behind the operator controls,and the pto drive needs to be where it is...I tried fitting my kubota d1105 in my ventrac..its 4" too long,simply wont fit without moving radiator rearward or losing cooling fan,neither which are possible...the 31 Briggs Diahatsu gas or diesel is a very compact engine,only 15" long,which is probably why they are the only LC engines in use in them....The Steiners have the same amount of room,so nothing bigger than the 950 will fit in the new tractor...the 430 only could get the d721 in there...not even close to big enough.
The 3Lc engines the are in the Ventrac tractors right now will not meet emissions for 2013, so they will have the same hp/cc problem with there new engines!
/ STEINER 440 #14
I don't know the dimensions but it was quite a bit longer/larger than the 430. (see below)
You may be happy about that foot lever in theory. May be ok on long flat ground, but I would never take that thing on a slope or in tight areas :eek: that is an accident waiting to happen.
@Raw Dodge
I agree on engine, but I believe they were limited on Diesel engines due to EPA regulations and that will be for anyone in this hp range, but you probably know more about it than I do :laughing:.
I was also told that they are using the same axles that Ventrac currently uses and designed years ago. So it should be a good axle, but then again it seems like they are playing catchup/copycat.
After digging a little I found some information on a dealers site.
Steiner - 440-40KO
So same axle that Ventrac designed (Peerless 2600).
430 is 64" the 440 is 86" with the same width :confused: 22" increase in length, wow.
So they definitely made it longer and quite a bit taller, with the same width.
Tire to tire the 440 is only 5" longer and has a tighter turning radius than the 430.
/ STEINER 440 #15
I heard Kubota gas and diesels were being tested in the Ventracs...but its just what i heard thru reliable sources I cannot mention here..:). I am glad they wont meet emissions,since the gas version is gone,parts are hard to find and expensive,and most importantly the diesels are complete garbage especially compared to the Kubota and Yanmar small diesels.There are no good engine options left for 4200 ventracs,its sad dropping to the Ventrac 3000 series gets you the Briggs D850 which for whatever reason is stone reliable and a great engine.So a Ventrac 4200,a few inches longer opens up possibilites for larger,more powerful gas and diesel engines,with the room to adequetley cool them,and additional room for a potentially larger or dual hydro pump setup....which is what they really need to be perfect.
/ STEINER 440 #16
The 430 didnt turn tight enough,so thats not saying alot. The older 420s,with the front axle hydro oil pickups turned tight,thats the target Id like to see met...If I had known that the later 420s and 430s had lost so much turning radius,Id never bought one,Id waitied for a used older 420,they are that much better,especially for mowing.
/ STEINER 440 #17
They made a kit to make the turning radius tighter for the 430's but people would leave it like that and then try to run it with dual wheels.
/ STEINER 440 #18
Never knew about the kit to make the 430 turn tighter...are you talking about the 3 holes in the frame that you could reconnect the hydraulic steering cylinder to in order to make it turn tighter?
I would hope it is not a optional accessory kit, steiner and ventrac both like to charge for anything they can. My first steiner410 the dealer charged me an extra $2100 for the air in the tires!:laughing: He said it was a must have accessory. :laughing:
hopefully the 440 does well...a new steiner or ventrac would be nice.
/ STEINER 440 #19
My later 420 was limited by the metal hydraulic suction hose for the pump.Turning any tighter would have the cylinder hit that line.I wanted to make it turn like my old 420,as none of my operators wanted to use the newer machine,between that and the way Steiner plumbed the hydros on the 97s,to go to the front axle first,the machine didnt have nearly the traction the old one did.No one would use it unless the other one was down or I forced them too.The newer 420s and 430s pulled oil from the rear axle,instead of the front like older 420s and ventracs.
/ STEINER 440 #20
What made the traction worse...not sure i follow?
Also, why did they go from a machine that pulled fluid from the rear axle? wondering what their thinking was?
Rainbow Self-Propelled Volume Gun (A53317)
Rainbow...
2017 Yale GLC050VX 3,500 lb LPG Forklift - Powershift, Aux Hydraulics (A61307)
2017 Yale GLC050VX...
EZ-GO Electric Golf Cart (A60462)
EZ-GO Electric...
40' High Cube Multi-Door Shipping Container (A60463)
40' High Cube...
CFG Industrial H12R (A60463)
CFG Industrial...
2021 QUALITY CARGO, LLC QUALITY CARGO, LLC (A60736)
2021 QUALITY...
