Cold start problem
/ Cold start problem #1
BeezFun
Elite Member
IL
Kubota B2710
I have a commercial Toro ZTR, never had a bit of trouble but it's always been really hard to start when cold and it's getting worse. It has a 25hp kawasaki FH721D engine. Over a few years I've replaced plugs, wires, and fuel pump (it was leaking slightly). It's started hard since it was new but never made it back to the dealer when it was under warranty because it wasn't as bad. It doesn't matter much what the temp outside is, it starts very hard even when it's 90 degrees out. Starts great once it's been run for a few minutes.
tnx
/ Cold start problem #2
i'd go with a weak coil. check that out.
Can I measure resistance on primary and secondary side to identify weak coil, or do I need to take it someplace that can test it?
500 GALLON FUEL TANK (A64278)
500 GALLON FUEL...
2022 EZ-GO ELITE...
2000 Chevrolet Astro Cargo Van (A64194)
2000 Chevrolet...
2010 Ford F-250 4x4 Crew Cab Pickup Truck (A64556)
2010 Ford F-250...
2008 FOREST RIVER CARDINAL 30RK 5TH WHEEL (A65643)
2008 FOREST RIVER...
2014 Ford F-150 4x4 Ext. Cab Pickup Truck (A64556)
2014 Ford F-150...
