601 ford
/ 601 ford #1
Mitch2144
Trenton Fla
53 601 ford
My lift arms came up, while i was Bushhogging. They wont go back down unless i shut the tractor off. But when the tractor is started up again, they come back up, and wont go down, even with the lift lever all the way down. Any Help would be appreciated. Thanks.
/ 601 ford #4
i agree.. classic sticky unloader valve.
while you have the top cover off.. check oil.. if dirty.. flush sump and change hyd oil.
ps.. top cover gasket and oring kit is a paltry 15$ at your dealer..
/ 601 ford
Thanks Soundguy. Do you know what oil goes in there? iI will prolly go ahead and change it. Thanks.
/ 601 ford #6
i reccomend utf fluid meeting the m2c134 spec ( walmart, tsc, napa, car quest, etc.. all have house utf oils. check pail for spec.. most run 30-50$ per 5g. ) takes 8qts in hyds nominally. will hold up to 4 qts more -if- you use external hyds..
Club Car (A59231)
Club Car (A59231)
Enclosed Trailer (A61569)
Enclosed Trailer...
EXCAVATOR RIPPER (A58214)
EXCAVATOR RIPPER...
Toro Zero Turn Lawn Mower (A56859)
Toro Zero Turn...
2012 International WorkStar 7400 Service Truck with Crane, VIN # 1HTWGAAR2CJ453403 (A61165)
2012 International...
2025 HD Trailer Solutions EQ15 T/A Equipment Trailer (A59230)
2025 HD Trailer...
