Can't weld aluminum with DC TIG but can with DC MIG?
   / Can't weld aluminum with DC TIG but can with DC MIG? #1
undercut
WA State
Nothing at the moment
Why is it that I see people who can weld aluminum with DC MIG but DC TIG, you can't?
   / Can't weld aluminum with DC TIG but can with DC MIG? #2
Who told you that? Here is a aluminum Tig weld done on DC.
I see so many DC inverter TIG products that specifically state they will not weld aluminum (well).
   / Can't weld aluminum with DC TIG but can with DC MIG? #4
When Linde now ESAB invented Tig welding it was all DC, with helium gas.
I actually wanted to know why someone can MIG aluminum with argon but can't TIG aluminum with argon.
   / Can't weld aluminum with DC TIG but can with DC MIG? #6
Well allow me to talk out of my behind for a moment...:laughing:
For TIG, as I understand it, Ar does does support as high of a ionization potential as He does, so you don't get as much heat into the weld quickly enough. Since Al is such a good conductor, you need to supply a lot of heat fast to weld without just melting the whole thing into a blob. Using AC cleans off the oxide also, making the weld better as it removes the oxide that can contaminate the weld. There is some relation to the oxide cleaning in why DC TIG on AL is so much harder, I think.
Here's an explanation:
Why can't you TIG weld Aluminium with DC current?
MIG is a different animal as the electrode is also the filler. I assume that makes the difference, though I won't even try to guess why....I've already made up enough stuff for one post.:laughing:
   / Can't weld aluminum with DC TIG but can with DC MIG? #7
One nice benefit to Tig welding aluminum on DC with helium, is you can do the same thing as with AC but it only takes about half the amps.
Down side is, you don't get as much cleaning action out of the arc, and there is a very small window where the arc will start.
   / Can't weld aluminum with DC TIG but can with DC MIG? #8
Here is a good read that might interest you. I did not know the history of Tig until googled it. I often wondered who invented it, when it was invented. The first I heard about it was aboard ship in 1965. No offence intended
History of TIG Welding
This information came off another site.
Development
After the discovery of the electric arc in 1800 by Humphry Davy, arc welding developed slowly. C. L. Coffin had the idea of welding in an inert gas atmosphere in 1890, but even in the early 20th century, welding non-ferrous materials like aluminum and magnesium remained difficult, because these metals reacted rapidly with the air, resulting in porous and dross-filled welds.[2] Processes using flux-covered electrodes did not satisfactorily protect the weld area from contamination. To solve the problem, bottled inert gases were used in the beginning of the 1930s. A few years later, a direct current, gas-shielded welding process emerged in the aircraft industry for welding magnesium.[3]
This process was perfected in 1941, and became known as heliarc or tungsten inert gas welding, because it utilized a tungsten electrode and helium as a shielding gas. Initially, the electrode overheated quickly, and in spite of tungsten's high melting temperature, particles of tungsten were transferred to the weld.[3] To address this problem, the polarity of the electrode was changed from positive to negative, but this made it unsuitable for welding many non-ferrous materials. Finally, the development of alternating current units made it possible to stabilize the arc and produce high quality aluminum and magnesium welds.[3]
Developments continued during the following decades. Linde Air Products developed water-cooled torches that helped to prevent overheating when welding with high currents.[4] Additionally, during the 1950s, as the process continued to gain popularity, some users turned to carbon dioxide as an alternative to the more expensive welding atmospheres consisting of argon and helium. However, this proved unacceptable for welding aluminum and magnesium because it reduced weld quality, and as a result, it is rarely used with GTAW today.[5]
In 1953, a new process based on GTAW was developed, called plasma arc welding. It affords greater control and improves weld quality by using a nozzle to focus the electric arc, but is largely limited to automated systems, whereas GTAW remains primarily a manual, hand-held method.[5] Development within the GTAW process has continued as well, and today a number of variations exist. Among the most popular are the pulsed-current, manual programmed, hot-wire, dabber, and increased penetration GTAW methods.[6]
   / Can't weld aluminum with DC TIG but can with DC MIG? #9
That is very interesting! So Linde bought the patent:laughing:. Can't tell you how many times over the years I've read where Linde invented the process. I'm sure I've even read it in welding books. Goes to show you, don't always believe what you read, wait a minute! Am I believing what was printed in your link? :laughing:;)
   / Can't weld aluminum with DC TIG but can with DC MIG? #10
That is very interesting! So Linde bought the patent:laughing:. Can't tell you how many times over the years I've read where Linde invented the process. I'm sure I've even read it in welding books. Goes to show you, don't always believe what you read, wait a minute! Am I believing what was printed in your link? :laughing:;)[/QUOTE
Shield arc I am not trying to pick a fight with you in any way, I am just sharing information that I have found. I would like to give credit where credit is due.
What I posted was not to offend you in any way. Here is another comical link that they claim was researched. You should get a few laughs out of this also.
Who invented tig welding? | Answerbag
I found another link, It's 125 years of Linde http://www.the-linde-group.com/en/images/chronicle_e[1]14-9855.pdf
On page 46 I found the only reference to electric welding
During the war, Ellira (Elektro-Linde-Rapidschwei゚ung), the
electric welding systems department established in H?lriegelskreuth in 1937, worked almost exclusively on supplying welding
equipment for the arms industry.
On page 86 and 87 they have milestones of Linde From 1879 to 2004, they never mentioned their invention of the Tig welding process. They either forgot to put it on the list or it was such an insignificant invention it was not worth mentioning.
I will look some more and see if I can find somewhere where Linde claims they invented the process.
Can anybody else on here help me out?
2017 GMC SIERRA 1500 (A53843)
2017 GMC SIERRA...
2016 John Deere 35G Mini Excavator (A55973)
2016 John Deere...
Deere 331G (A53317)
Deere 331G (A53317)
2015 RAM 5500 Bucket Truck w/ Versalift SST40 boom -Cummins Diesel - Auto Trans- 4X4 - 72096 miles (A55302)
2015 RAM 5500...
DYNAPAC CC5200VI DBL DRUM ROLLER (A52707)
DYNAPAC CC5200VI...
2022 CASE CX57C EXCAVATOR (A52707)
2022 CASE CX57C...
