Buying Advice yanmar ym3810D
/ yanmar ym3810D #1
dirtmover57
enterprise,al
yanmar
Looking into buying a Yanmar 3810 D with loader. Anybody know much about this tractor? Price range ect .......
/ yanmar ym3810D #2
Welcome to the forum!
I have one and like it real well ask away btw we are few and far between us 3810 drivers. :laughing:
Actually why dont you tell us a little about what you are looking at hours condition who is selling and what you are needing out of your tractor and so forth may help us help you. :)
/ yanmar ym3810D #3
Looking around the internet a little and I see them with a loader from 11,500 used to 14,500 supposedly reconditioned.
/ yanmar ym3810D
Well,I'm looking for 45-55 HP with from loader. I own 80 acres farm and I need a tractor for farm chores. I don't know if this tractor will pull set of disk and moved 1200 lbs. Hay roll for cows. That type stuff.
/ yanmar ym3810D #5
Well the 3810 will produce 38 HP at the PTO. Is this enough?
/ yanmar ym3810D #6
Wait for rScotty to show up. He always has good advice. He has owned similar Yanmars for 30 years and also owns larger utility tractors for the sort of work you describe.
I suspect he will say you need a heavier real utility tractor to handle round bales safely. I think your 3810 is the turbo version of his (US) YM336 so no heavier than a 336 despite the greater horsepower.
Most any Yanmar has more horsepower than traction so I'm not sure the 3810 is a first choice for real-farmer discing, either, where more weight helps get the power to the ground.
/ yanmar ym3810D #7
dirtmover,
Its going to do a lot of what you need very well and inexpensively fuel cost wise you will be suprised. It will have a lot more power than traction as California also says these Yanmars are known for that - plus more gears than carter has liver pills.
The disc I pull in hard dirt with no problems is a small one @ 6.5' wide with a 350# weight on it and it is barely noticeable on back. What size max and what ground it would pull in is hard to say but it is a cat 1 so the sizes are limited fwtw. my .002
I can lift 1500-2000# with my Koyker 160 loader with 700# of rear wheel weights on so a 12-1500# round bale is doable if the tractor balance is right its not the safest but is possible.
Whether I would do it every day of the week - yes I probably would but carefully just depends on the ground and how far to carry etc. The tractor only weighs something like 3500# w/loader its not a heavy machine by any stretch and they are narrow track @5' wide. btw the US spec 336 and the Jap market 3110 are the same chassis etc and the JD 1050 is a sister to the 3810 just has gear trany.
Reason being is with the front ends and tire size on these they were not designed for loaders and you will hear story's of guys breaking front axle stubs not a lot but enough to merit caution. I believe the 3810's and probably the US market 336 have all the heavy duty parts in them that Yanmar built for this chassis (if they built any) but that is purely my opinion I have no proof. my .002
The other thing to consider is external hydraulics these dont have them. You will have to plumb in what you need luckily this tractor is very simple to do so just didn't have a factory plumbing like the US tractors mostly do. good luck :thumbsup:
JMR Tree Boom Mini Skid Steer Attachment (A64553)
JMR Tree Boom Mini...
2024 BOBCAT TL619 TELESCOPIC FORKLIFT (A65053)
2024 BOBCAT TL619...
JOHN DEERE 467 ROUND BALER (A64278)
JOHN DEERE 467...
2003 CASE 70XT SKID STEER (A65053)
2003 CASE 70XT...
REDDICK 300 GALLON SPRAYER (A64278)
REDDICK 300 GALLON...
2004 Caterpillar 315C Hydraulic Excavator (A64194)
2004 Caterpillar...
