Winco 12PTOC-3/B 12kw PTO generator
/ Winco 12PTOC-3/B 12kw PTO generator
Well even though noone responded to this thread for a price check I bought the Winco for $600 and the guy threw in a Wallenstein PTO shaft plus a decent mount.
He demonstrated it, it ran fine. Like many other purchasers of generators he bought it AFTER a major storm, and put hardly any hours on it.
/ Winco 12PTOC-3/B 12kw PTO generator #3
Congrats sounds like you got a heck of a deal. I was one of some that read your original thread starting post,however did not know anything about topic so had no comment. Maybe when you can post a pic or two and give us more feedback. :thumbsup:
Txs
Boone
/ Winco 12PTOC-3/B 12kw PTO generator #4
Just noticed this thread. You got a great deal on a solid generator that should run a whole house.
Depending on the surge rating of the 12PTOC you may want to temporarily switch off the biggest motor loads then bring them back after everything else is running, but the generator should run it all fine after that. Use big wire (#8) between the generator and your panel - if the run is more than 20-30 feet #6 will maintain the voltage better.
I got a similar deal on an older Winco 25/15 (15kw continuous, 25kw surge). I bolted it to the barn floor with its shaft sticking out a hole in the wall for the tractor pto. The house is 150 ft away and is connected with #6 wire and 60a breakers.
The key to pto generating is steady control of tractor rpm. Some tractors have rock-steady governors but some don't. I use a couple of these Voltage / Frequency Meters - one at the tractor and one in the house to keep an eye on things.
/ Winco 12PTOC-3/B 12kw PTO generator #5
Did you find this one on the Baltimore Craigslist, by chance?
There was one (same as the one you have) just across the Bay Bridge for $600...
I missed it by a day!
Txs
Boone
Finally found a pic -
attachment.php
2014 Freightliner Bucket Truck (A56438)
2014 Freightliner...
2026 DEVELON DX27Z-7 EXCAVATOR (A64279)
2026 DEVELON...
2020 INTERNATIONAL LT625 48" SLEEPER (A62613)
2020 INTERNATIONAL...
Caterpillar TL1055D (A62177)
Caterpillar...
Arrow Quip 10' Bow Gate (A64047)
Arrow Quip 10' Bow...
1998 Volvo VNL64T Sleeper Truck (A62679)
1998 Volvo VNL64T...
