MY2012 5085M ordered today!
/ MY2012 5085M ordered today! #321
972 lbs according to Owner's manual.
I hope to try it out this weekend along with my stump grinder unless it is too wet.
They say rain saturday and clear Sunday. What does your HD bucket weigh?
HD bucket is 676 lbs according to the spec sheet I got. Probably more like 720 lbs now that I put those big teeth on it. :D
/ MY2012 5085M ordered today! #323
Nice finished product! Sweet looking rig for sure. Only thing I don't understand is you say it started raining, so you put everything away, was the cab leaking??:laughing:
:laughing::laughing:
Nah, but I wanted to install the PB kit and complete the oil collection system on the rear remotes before heading out into the woods.
Also, now that I finally have the loader, I can put on my pallet forks and get that metal roofing raised up and installed. All that non pressure treated, untreated lumber isn't really digging all this rain. :(
Got the PB kit installed along with the oil collection system. Turned out pretty nice I think.
So I put the pallet forks on and figured I'd see what the loader was capable of.
This was just above idle (1200 rpm). I'm impressed!
/ MY2012 5085M ordered today! #326
Peter, Do you wipe your feet before entering the cab?:D
/ MY2012 5085M ordered today! #327
so whos the poor sap that lost their car? :D almost looks like your going to need some more rear ballast
/ MY2012 5085M ordered today! #328
FANTASTIC! Lifting the car should give you Picture of the Year!
The tractor looks really good! You are going to have a ball. Every time I use the tractor I smile and today it was raining and I was unloading One ton bags of lime on pallets and thinking, yup, that's why I have a cab!
/ MY2012 5085M ordered today! #329
I can see several differences in your single point coupler. The handle is down when coupled, mine is up. Yours has a tubular handle, mine a flat bar. Does yours have a provision for a wire connector, I could not tell from the pictures? Is yours made by Faster?
Grapple hoses may have to be long enough for older loaders with the couplers mounted a lot higher than yours. My grapple needs the hoses longest when completely dumped. I tie wrapped a tarp strap to my hoses then to the grapple to keep the hoses from hitting the ground. They form an "S" and will stretch out when fully dumped.
Nice you were able to upgrade the bucket from 73" to 85". I knew the HD "was" available without grapple brackets, but may have been discontinued, meaning all new ones have the grapple brackets. Cost of the brackets might be cheaper than the logistics of having two parts numbers and buckets to warehouse.
That car pickup shows a lot of lifting power! Have you checked the loader manual for ballast reccommendations? I am surprised it did not lighten the rear with that lift!
I didn't attempt to actually drive around with the Saab, but I plan to have the stump grinder on the back most of the time when using the grapple.
I didn't actually get a operator manual with the loader, just the installation instructions. Will check back with the dealer on that next week.
Zebra, I did not notice any provisioning for a wire connector. I have not yet uncoupled mine. I'll be sure to take a look when I do. I'll also get back to you on it being a Faster or not. I know the boom mounted 3rd function is Faster, so the main one probably is as well.
I cobbled together a 22' extension for the pallet forks to allow me to put my 24' roof panels up on the roof by myself.
1st panel loaded
From the front
It worked! Here is it after being fastened to the roof.
So far this tractor sure hasn't disappointed!
/ MY2012 5085M ordered today! #331
Awesome thread. Beautiful tractor.
I can't wait till the other house sells so I can order one!
Zebra,
How are your hoses routed to your single point connection?
Here's what mine looks like:
They are rather exposed to getting snagged by brush/slash in the woods.
The installation manual shows a hose holder as seen here:
Does your tractor have this? I looked at my mounting frame, and I don't see bolt holes for such a bracket, which I suppose is why it wasn't installed.
I plan to re-orient the hose fittings to be more horizontal instead of being angled down, and then figure out some way to tuck the hoses against the frame.
Another concern I had was that, on about every 5th start up, once the engine is running, the following 2 indicators stay lit and I get a warning beep. They go away after about 10 seconds.
H is the Engine Information Indicator and Operator's Manual states:
--- cut ---
If engine information indicator remains illuminated after starting engine, stop engine immediately.
Check engine oil level, engine oil cooler, and engine oil filter. If low oil level is not the problem, see your John Deere dealer.
--- cut ---
I of course checked the oil level and it is right at the high mark.
I is the Service Alert Indicator and the Operator's Manual states:
--- cut ---
Indicator illuminates when a malfunction occurs (review error messages in information display). If necessary, have John Deere dealer diagnose vehicle.
NOTE: Correct problem before restarting.
--- cut ---
Like I said, it only happens on about every 5th start up, although it has happened 2 or 3 times in a row, but it always goes away after about 10 seconds.
Could this just a false positive type indication being that I only have 8 hours on the engine?
/ MY2012 5085M ordered today! #334
Zebra,
--- cut ---
--- cut ---
--- cut ---
--- cut ---
My loader valve is mounted horizonal compared to yours. (I'll take some pictures and post later). The outlets for the hoses face down. From the frame out, two rows of three. The forward row has 90s the rear row has long sweep 90s. My hoses do not hang below the frame at all.
Your hoses look too long.
My loader does not have the lower hose holder.
No idea on the two lights. If the oil level is OK and they go out after 10 seconds hard to say what is going on.
/ MY2012 5085M ordered today! #335
With the length of your hoses I would try routing them up at about a 45 degree angle forward (between 1 & 2 O'clock) then let them loop down, then back up to your MultiCoupler.
Looks like your third function has flow control? Black knob. Make sure you don't run a hose over or too close, so you can still adjust it.
Looks you like you also have 90s on the forward row and long sweep 90s on the rear row. Should be easy to change.
I'll play with routing the hoses up at an angle instead of down or horizontal and then tie them in towards the frame to get rid of the slack. It sure would have been nice if they had a hardline option for the single-point connector.
Talked to the service department about the 2 lights that stay on after starting the engine. The guy I spoke to will have the service manager call me. He said it was definitely not "normal".
I started the tractor 4 times yesterday (for each roof panel I was getting up on the roof) and it did it on the 2nd start. There are actually 5 beeps in rapid succession when those light stay on.
Hopefully its just a code or something that needs to be cleared out of the computer.
I got my hydraulic top link from Brian today. Awesome workmanship I must say!
I need to figure out a "OEM looking" way of holding it up when I don't have an implement connected. I guess a Bungee cord will do for now.
Oh, and here's a pic of my HD bucket with the teeth on it. :D You can also see I made good progress in the pole barn extension to my shop in the background.
/ MY2012 5085M ordered today! #338
Here are pictures of the hoses from the mid valve to the multicoupler. There were two big wide tie wraps on the hoses. I cut them off when I swapped from quick couplers to the multicoupler. I have not bought replacement large tie wraps yet. The boom hoses were too tight so I added some 45 degree fittings to make them longer (cheaper than new hoses) I also had to adapt from JIC to ORFS. My hoses were JIC, the multicoupler is ORFS. This is not as clean/simple as I would have liked, but I did not want to buy 12 new hoses.
I been working on an idea for a different bracket for the multicoupler to turn it 90 degrees, like yours is. Then it will stick out almost 6" less.
/ MY2012 5085M ordered today! #339
My plan ( when I get a hydraulic toplink) is to buy the metal top link handle from JD parts. Get a band style exhaust clamp ( I think 3 1/2" will work) Weld a block with holes drilled in it for the top link handle to the band clamp. Determine the correct positon, tghten it down and a little JD green paint and it will look and work factory.
/ MY2012 5085M ordered today! #340
Peter,
I may have missed it, but where did you get the bolt on teeth for the bucket? I'm looking for something like that for my 410 backhoe.
