John Deere 4410
/ John Deere 4410 #1
Savage11
Bowling Green KY
John Deere
I have a John Deere 4410 that I bought about 4 months ago. This is my first tractor and do not know very much about them. I have noticed recently that there is a leak somewhere around the left rear tire. I was wondering if anyone could explain to me how I can fix the problem either:
1. A thickener that I can add to the oil
2. If it's easy to replace the seal and how or if it is a big job
3. Or if I just need to take it to the John Deere shop?
Thanks for any help provided!
/ John Deere 4410 #2
:welcome: to the forum.
No need to take it to a shop if you have some interest, tools, and skills to do it yourself.
Whether it easy or a big job depends on you. It will be different for different people.
Give us an idea what your background is, and we might be able to give better suggestions for you. Have you done a search on TBN to find some threads on the axle seal?
Basic, to me, would be to get the service manual, regardless if you are going to do it yourself.
And what is the second pic showing, and does it have any connection to the leak that appears to be dripping down on the rim and then down across the tire?? Pinpointing the leak would be the first order of business.
Forget the thickener idea. Not likely a solution or a possibility.
/ John Deere 4410 #3
I am not sure if this will help but you look to be over full on your hydro oil. You should be able to see the top of the level in the sight glass. I am not sure if that is the cause of your leak but it is possible.
/ John Deere 4410
To: mfreund
I see a small bubble in the sight glass. It is to the very top.
/ John Deere 4410
I will check the manual again this evening. I did not see anything on it when I looked the first time.
/ John Deere 4410
Are your tires loaded? Did you check the hydraulic connections right above?
Thanks you for your comment.Yes, the leak is around the axle next to the tire. It is the only place that I seen that has oil on it.
/ John Deere 4410
There is a small bubble in the top of the sight glass. It is filled to the top. Should it be a line straight across?
/ John Deere 4410 #9
When parked on a level surface the hydraulic fluid should be just slightly higher than half way up the glass. There are a few seals that can leak on the wheels. It is more common to see the front wheels leaking. Be sure to check the level of them. As for adding a thickener. Is it an eHydro if so then it is one sump of hydraulic fluid to thicken it would effect your total performance so it wouldn't be recommended.
Download a copy of the service manual. A search engine will find you several copies for download for $25 or less. 800 pages of how to fix everything. After you review how to do the repair answer the question of can you do it yourself.
207274 (A52708)
207274 (A52708)
2017 CHEVROLET 5500HD LCF S/A 4X2 24FT BOX TRUCK (A59910)
2017 CHEVROLET...
Bad Boy MZ Rambler Zero Turn Mower (A64047)
Bad Boy MZ Rambler...
2020 DRAGON ESP 150BBL ALUMINUM (A63569)
2020 DRAGON ESP...
*Selling at Royal Auction Tampa, FL Location* (A59231)
*Selling at Royal...
2021 Polaris Ranger 1000 (A64047)
2021 Polaris...
