Kubota B3200HSD Hydraulic Fluid Question
/ Kubota B3200HSD Hydraulic Fluid Question #1
hailofaguy
Member
Kingfisher, OK
Kubota B3200HSD
I have a 2011 B3200HSD with a Kubota FEL - Model #B1625.
My question is this. What type of Hydraulic fluid does the tractor/FEL take? Does anyone know the specs or if another brand will work?
The dealership only has large quantities of the Kubota Hyd Fluid and I just need a small amount, quart or less, to refill it.
/ Kubota B3200HSD Hydraulic Fluid Question #2
recommends the kubota udt, kubota super udt, or kubota super udt2 trans/hydrolic fluid. specs state the udt oils will mix with other universal trans/hydraulic oils. you can buy the kubota udt oils in a 2 gal jug. (lowest quanity i know of) you will need it when you do your pm change, so i would recommend buying the kubota product and then you will have it on hand for later on. i have only used kubota super udt/udt2 oil in all my kubota equipment. others have used different oils, but... i think cheveron is a name others have used sucessfully, maybe mystic oils too. search here on tbn and you should find results, but i recommend the kubota sudt2. good luck.
/ Kubota B3200HSD Hydraulic Fluid Question #4
Buy a gallon or 2 gallon of what dealer has. Use what you need now and have the rest on hand for alter PM or emergency. Never know when you might rip off or blow a hose.
/ Kubota B3200HSD Hydraulic Fluid Question #5
Messicks sells it in all sizes. I just picked up a couple quarts of super UDT for when I change my HST filter and to have some spare around.
2025 IRANCH IRLMB Mixing Bucket Mini Skid Steer Attachment (A61572)
2025 IRANCH IRLMB...
2010 GMC W5500 HD 16FT Box Truck (A61573)
2010 GMC W5500 HD...
UNUSED WOLVERINE UNIVERSAL MOUNTING PLATE (A64281)
UNUSED WOLVERINE...
Coleman Sky Lodge Instant Screen House (A62613)
Coleman Sky Lodge...
2022 EZ-GO ELITE...
UNUSED WOLVERINE BUCKET (A64281)
UNUSED WOLVERINE...
