Hydraulic weed eater
/ Hydraulic weed eater #1
Rhinorider
Clarksburg, WV
Kubota B1550, Kioti DK45 HST
I have been kicking an idea in my head of building a tractor mounted hydraulic weed eater to cut steep banks with, and was wondering if anyone has done anything like this.
It is basically like a boom mounted brush hog, but only a whole lot lighter. I have access to some 2" fiberglass solid rods about 10 feet long. I am thinking of using a hydraulic motor to spin up the head and use either small diameter steel rope or chain saw chain for cutters. 3 small cylinders to adjust the reas and angle of the boom and head.
I could drive along the bottom of these steep banks and cut 1/2 way up, then drive along the top and reach the other half.
I'm thinking 3 pt mount, its own set of controls, cut width 36-48", total reach about 15 feet, a spring loaded break-away mount for the boom in case of hitting an unseen object that would other wise break the boom.
What do you all think of this idea?
/ Hydraulic weed eater #2
I like it and would like to do the same. I seen a picture of one the guy used a 2 cycle engine and only about a 21" cut, it looked real good. I have had my eye out for a old lawnboy, but no go. I don't know much about hyd. motors as for sizing. Do you think the 2" fiberglass solid rods would be better and lighter then alum.?
Lee, I think these rods are about the same weight, maybe just a tad heavier, but I am sure they are stronger.
/ Hydraulic weed eater #4
Here is the PowerTrac boom cutter, and some others built by a PT owner Stray.
Yea JJ thats what I'm talking about. Only I need a longer reach, the hills here in WV are higher. :laughing: I'll take some pics of what I have to cut. Maybe I should rethink it and mount a brush hog on a small dozer.:thumbsup:
/ Hydraulic weed eater #7
It is basically like a boom mounted brush hog, but only a whole lot lighter. I have access to some 2" fiberglass solid rods about 10 feet long. of using a hydraulic motor to spin up the head and use either small diameter steel rope or chain saw chain for cutters. 3 small cylinders to adjust the reas and angle of the boom and head.
* I am thinking about useing small diameter steel rope
What do you all think of this steel rope idea?
*Do not use steel rope .
It's dangerous because the ends fray easy and become harmful flying projectiles when they break off.
/ Hydraulic weed eater #8
Here they use a boom with about three hyd motors on them with large saw blades to cut tree limbs. Not sure you want blades on the ground in WV due to rocks. A few years ago there was a company in Ohio named something like Mico Mowers who made a boom mounted hyd motor string trimmer. Don't find them right off on Internet so no idea if have name wrong or what.
/ Hydraulic weed eater #9
Rent a 'hydraulic' goat.
Bunch of sheep will do the same; will simultaneously add hydraulic fertilizer to the equation.:licking:
/ Hydraulic weed eater #10
I have thought about something like this for quite awhile myself. My app is similar to yours, banks along a path, banks along a creek,etc. and other areas that I can't run a lawnmower,brush-hog...or the stuff is too heavy for a weed-eater.
The other day, after reading here....it re-vitalized my interest.
I have a hydraulic concrete saw that is 14". I put a 14" carbide tooth wood blade on it, and temporarily C-clamped it under my backhoe bucket. I breifly tested it by putting the boom straight out at an angle and then tilted the bucket for the blade angle...and drove down one of my paths with a hill on one side.....it works darn good....I then backed into a huge multiflora bush and proceeded to wipe it out.
I was controlling the saw with the remote rear hydraulics via a selector valve near my seat. The trigger on the saw held with a tie-wrap.
I think I will now make an adapter that bolts on to the buckets' water weep holes and clip onto the cutting edge too.
One thing I did notice that is a problem, is when lowering my main boom...it is way too fast of a drop...not a problem digging, but too fast for this thing. Too easy to ruin an expensive saw and/or blade.
I am still going to do it though....I will add a skid plate type of thing so I can't mash the thing into the ground. I don't need to cut that short anyhow.
Hopefully I can post a few pics soon.
/ Hydraulic weed eater #13
I'd like a large tractor-mounted string mower also. Fire season starts today around here. Cut the firebreaks last week with my offset disc. Now I've got a stand of yellow star thistle in my hayfield. I'll wipe it down with glysophate herbicide later this week. When it's dead, it's fire tinder that you don't want to mow with a metal bladed implement (rocky soil, sparks, here comes CFD to put out the fire and hand you a bill for their services). I hope to learn a lot from this thread so I can take a whack at some sort of jumbo string mower later this year. Sounds like a fun project:D
/ Hydraulic weed eater #15
/ Hydraulic weed eater #16
Hey, that's one neat string mower:thumbsup:
I'm all set up with an SSQA on my FEL. Just need to route hydraulic lines to the front of the Mahindra 5525 and build the mower.
Thanks for the info.
It's high on my "to build" list ;)
2022 CORMIDI C85 STAND-ON MINI DUMPER (A62129)
2022 CORMIDI C85...
1985 CADILLAC SEVILLE (A60736)
1985 CADILLAC...
2016 Chevrolet Sonic LS Hatchback (A56859)
2016 Chevrolet...
Year: 2014 Make: Volkswagen Model: Passat Vehicle Type: Passenger Car Mileage: 135,272 Plate: Body (A56859)
Year: 2014 Make...
Zero Turn Mower (A59231)
Zero Turn Mower...
2006 Honda Ridgeline AWD Crew Cab Pickup Truck (A61568)
2006 Honda...
